Microsoft Lifecam VX 700
I followed this document from a Chris's Basement video: https://docs.google.com/document/d/1AqtBhPTZOei1bds82Q2bN_Hy5QSHhvsh3vqAmPzSiJo/edit
When I try to test mjpg streamer I get a list of errors about pan, tilt, focus, etc. that I don't know the relevance of. When I look at the Control tab in OctoPrint the video window says "Webcam stream not loaded."
Nothing. I'm not sure what to do or where to look
When I try to test mjpg streamer:
~/mjpg-streamer/mjpg-streamer-experimental$ sudo ./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
MJPG Streamer Version: git rev: 85f89a8c321e799fabb1693c5d133f3fb48ee748
i: Frames Per Second.: -1
i: Format............: JPEG
o: www-folder-path......: disabled
o: HTTP Listen Address..: (null)
o: commands.............: enabled
^Csetting signal to stop
i: cleaning up resources allocated by input thread
force cancellation of threads and cleanup resources
o: cleaning up resources allocated by server thread #00
done
This is what octoprint.log shows. I do not have a webcamd log or anything like that.
2020-11-30 08:17:35,946 - octoprint.startup - INFO - ******************************************************************************
2020-11-30 08:17:35,964 - octoprint.startup - INFO - Starting OctoPrint 1.4.2
2020-11-30 08:17:35,966 - octoprint.startup - INFO - ******************************************************************************
(SNIP)
2020-11-30 17:32:43,592 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-30 17:33:58,285 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 33376}
2020-11-30 17:44:10,129 - octoprint.server.util.flask - INFO - Passively logging in user joe from 192.168.5.226
2020-11-30 17:44:10,133 - octoprint.access.users - INFO - Logged in user: joe
2020-11-30 17:44:13,571 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.55s
2020-11-30 17:44:14,801 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.91s
2020-11-30 17:44:15,611 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.71s
2020-11-30 17:44:16,434 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.73s
2020-11-30 17:44:17,161 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.55s
2020-11-30 17:44:18,431 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-11-30 17:44:18,874 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606779861587 (192.168.5.226) 18.60ms
2020-11-30 17:44:18,938 - octoprint.server.util.sockjs - INFO - User joe logged in on the socket from client 192.168.5.226
2020-11-30 17:45:03,373 - tornado.access - WARNING - 404 GET /webcam/?action=stream (192.168.5.226) 20.09ms
2020-11-30 17:46:23,246 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606779986987 (192.168.5.226) 20.98ms
2020-11-30 17:46:43,319 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606780007045 (192.168.5.226) 23.63ms
2020-11-30 17:47:43,595 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-30 17:48:57,983 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 34276}
2020-11-30 17:51:16,458 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606780280151 (192.168.5.226) 22.56ms
2020-11-30 17:51:51,747 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606780315420 (192.168.5.226) 20.01ms
2020-11-30 17:52:29,849 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606780353700 (192.168.5.226) 30.40ms
2020-11-30 17:56:45,037 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606780608921 (192.168.5.226) 26.30ms
2020-11-30 17:56:47,462 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.5.226
2020-11-30 18:02:43,599 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-30 18:03:58,125 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 35176}
2020-11-30 19:48:52,176 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606787336178 (192.168.5.226) 24.97ms
2020-11-30 19:48:57,480 - tornado.access - WARNING - 404 GET /webcam/?action=stream (192.168.5.226) 24.98ms
2020-11-30 19:48:57,820 - tornado.access - WARNING - 404 GET /favicon.ico (192.168.5.226) 26.70ms
2020-11-30 19:48:58,017 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 41476}
2020-11-30 19:49:07,980 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606787352063 (192.168.5.226) 25.21ms
2020-11-30 19:49:35,380 - tornado.access - WARNING - 404 GET /webcam/?action=stream&1606787379134 (192.168.5.226) 21.47ms
2020-11-30 20:02:43,628 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-30 20:03:58,153 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 42376}
2020-11-30 20:17:43,633 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-30 20:18:58,060 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 43276}
Linux Mint on a Dell Latitude 2100 running Octoprint 1.4.2
