T_T
March 8, 2020, 7:22pm
1
I have a Logitech C930e set up as a second web cam, and I use it only to check on my print every now and then. I want a high resolution image, but I don't need real video streaming, so I've done this:
camera_usb_options="-r 1920x1080 -f 1 -d /dev/video1"
However, when I look at the video feed in Octoprint, it's quite ovbious that it's running at faster than 1FPS. I'd say it's in the 5FPS range, at least.
Is it possible that the camera is not capable of such a slow framerate? Or is the driver ignoring the -f parameter?
Webcams typically support a fixed range of resolution/framerate/compression settings.
T_T
March 8, 2020, 8:47pm
3
Ah, I was doing the wrong google searches. I searched for "supported framerates" and discovered this command:
v4l2-ctl -d /dev/video1 --list-formats-ext
Which gives me:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2304x1536
Index : 1
Pixel Format: 'MJPG' (compressed)
So what I really want to use is this mode:
But this is listed under YUYV, which from I've read, uses significantly more CPU, which is the opposite of what I want.
You definitely want an MJPEG mode. Your 5 frames per second guestimate in your OP seems to be spot on.
Lah1r
March 13, 2020, 10:04am
5
When you set up your action cam, you can choose different resolutions and frame rates.
T_T
March 13, 2020, 1:03pm
6
I know, that's what the -r and -f options are for:
