Is there a tutorial on setting up a webcam or usb cam to Octoprint?
**Camera modelusb logitech c920 and Smraza Raspberry Pi 4 Camera Module 5
**What is the problem?Can not get either to view in Octoprint software. I can control my printer no problem
**What did you already try to solve it?*Changed octopi.txt fields: camera="auto" camera_usb_options="-r 640x480 -f 10 -y" camera_raspi_options="--x 1280 -y 720 -fps 20" Removed the # on each line. I have not changed the /webcam/?action=stream *
Logs (/var/log/webcamd.log, syslog, dmesg, ...)
**Additional information about your setup*Octoprint Ver. 1.3.11octoprint.log (282.0 KB) * (OctoPrint version, OctoPi version, ...)
Try searching the forum here for your webcam's brand and model to see if someone has provided this information.
Thank you for the reply, I did a search and found some info on the logitech camera but it was all about config changes after it is running. My problem is I cant get either running.
The documentation includes this page which might help.
Awesome thank you I will check it out
Also Chris Riley has a lot of tutorials.
Just seek his channel for OctoPrint and Cam.
