Issue with octopi cam- does not connect
Suddenly my camera stopped working and I get the message "webstream cam not loaded"
-try to change the direction in the setting to add my IP but didn't work.
-I changed ribbon
yep
no
Complete Logs
/var/log/webcamd.log
-bash: /var/log/webcamd.log: Permission denied
does somone know how to solve it please?
OctoPrint version 1.5.3, OctoPi version 0.18.0 , printer creator pro , firmware, browser, operating system, ... as much data as possible
Does that mean it stops after some time or doesn't work anymore at all?
you have to add something to that command - like nano to open it in a text editor. (nano /var/log/webcamd.log)
I would suggest that you use WinSCP to connect to your pi an download the log file.
It looks like a file explorer.
did it with putty. is this what i need??
thanks!!
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Dec 2 12:56:15 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
    i: Using V4L2 device.: /dev/video10
    i: Frames Per Second.: 10
    i: Format............: JPEG
    Error opening device /dev/video10: video capture not supported.
    i: init_VideoIn failed
Goodbye...
Starting up webcamDaemon...
