logitech c920
I can see the webcam content in 192.168.1.13:8080/?action=stream but when adding the path in the control panel /?action=stream nothing is viewable.
I followed the instructions in Setting up OctoPrint on a Raspberry Pi running Raspbian
My octopi url is 192.168.1.13:5000
Snapshot works and path to FFMPEG is working
if adding the whole local network to the stream, it works. Dont know if this is correct or no.
tried the haproxy way and nothing showed after installing it using the config in the manual
Could not find /var/log/webcamd.log
OctoPrint 1.3.12
