Issues connecting to FlashForge printer - Running 1.8.1 on RP 4b
When I upgrade to 1.8.1 from 1.7.3 I am no longer able to connect to my printer. When I down grade to 1.7.3 the printer will automatically connect with no issue.
I have looked through the help and forum but am unable to find a solution.
Yes. It makes no difference.
No. If I was to guess I would guess the problem is related to the FlashForge Plugin which is no longer maintained.
System Information
OctoPrint 1.8.1
Python 3.7.3
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.5005.125 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : True
connectivity.enabled : True
connectivity.online : True
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : True
env.hardware.cores : 4
env.hardware.freq : 1500.0
env.hardware.ram : 8202887168
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.4
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : True
octoprint.last_safe_mode.date : 2022-05-21T23:37:15Z
octoprint.last_safe_mode.reason : settings
octoprint.safe_mode : False
octoprint.version : 1.8.1
systeminfo.generated : 2022-07-04T16:10:10Z
systeminfo.generator : zipapi
Raspberry Pi 4B
Raspbian GNU/Linux 10 (buster)
Browser is Vivaldi 5.3.2679.58
Printer is flashforge Creator Pro 3
OctoPi Version 1.81
Hello @Modeller309 !
Could you please share the systeminfo bundle?
octoprint-systeminfo-20220704121010.zip (26.5 KB)
Here it is.
The octoprint.log is quite empty.
You may try this plugin:
I have restarted OctoPrint and collected some data in the system bundle.
I am using the plug in you suggested. It is no longer maintained. It works with 1.7.3 but not with 1.8.1 I assume something changed in 1.8.1 but don't know what.
octoprint-systeminfo-20220704125731.zip (30.7 KB)
As for the octoprint.log, the plugin works:
2022-07-04 12:53:21,879 - octoprint.plugins.flashforge - INFO - Found a FlashForge FlashForge Creator Pro 2 3D Printer, port:1:3
As for the github, the plugin still seems to be maintained:
Have you seen the configuration hints on that site?
The plugin is not maintained. See message on this page
Yes the printer is found but it does not connect. It times out with 1.8.1. When I move back to 1.7.3 it works with no changes on my part.
Sorry, I've overseen that section...
No issues. Happy someone is willing to take a look.
