Hi there,
Thank you in advance for your help.
I’m having issues heating my bed from a cold start to 105 C. I print in ASA and ABS and need a hot bed.
I run Marlin 2.1.2.1 on an AnyCubic Mega X.
I get this error:
State: Offline after error
Heating failed, system stopped! Heater_ID: bed - echo:busy: processing
I have tried:
- Booting in safe mode and still get the error.
- Changing the parameter as instructed here.
- Removing the SD card (read it on a forum).
Yes
Yes, provided.
Please see attached log file.
See M115 here
FIRMWARE_NAME:Marlin 2.1.2.1 (knutwurst, Github) (Jul 6 2023 16:35:09) SOURCE_CODE_URL:github.com/knutwurst/Marlin-2-0-x-Anycubic-i3-MEGA-S PROTOCOL_VERSION:1.0 MACHINE_TYPE:Knutwurst's Anycubic Printer EXTRUDER_COUNT:1 UUID:b6153152-86fb-4cd8-bda7-91c6a04c467d
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_POS:0
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:RUNOUT:1
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:1
Recv: Cap:HOST_ACTION_COMMANDS:1
Recv: Cap:PROMPT_SUPPORT:1
Recv: Cap:SDCARD:1
Recv: Cap:MULTI_VOLUME:0
Recv: Cap:REPEAT:1
Recv: Cap:SD_WRITE:1
Recv: Cap:AUTOREPORT_SD_STATUS:0
Recv: Cap:LONG_FILENAME:0
Recv: Cap:LFN_WRITE:0
Recv: Cap:CUSTOM_FIRMWARE_UPLOAD:0
Recv: Cap:EXTENDED_M20:0
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:ARCS:1
Recv: Cap:BABYSTEPPING:1
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: Cap:COOLER_TEMPERATURE:0
Recv: Cap:MEATPACK:1
Recv: Cap:CONFIG_EXPORT:0
Happy to answer and troubleshoot. I’m ok with coding and flashing firmware and stuff, but I can’t crack this one. Probably a random setting I’ve missed.
octoprint - heating bed issue - James.log (29.8 KB)
Thank you kindly.
James
