ERROR: octoprint-firmwareupdater 1.8.0 has requirement pyserial>=3.5, but you'll have pyserial 3.4 which is incompatible.
I've looked at the FAQ and logs but don't understand what to do.
N/A
octoprint.log (2.8 MB)
plugin_softwareupdate_console.log (232.0 KB)
serial.log (126.5 KB)
OctoPrint version 1.4.0
OctoPi version 0.17.0
printer Balco 3D Touch
firmware ADVi3++ 4.0.5 Build 200120232659, Marlin 1.1.9
browser Safari 14.0.1,
operating system Mac OS 10.15.7
Raspberry Pi 3 Model B Plus Rev 1.3
If you upgrade to a newer OctoPrint version (newer than 1.4.0) then this problem will be resolved, and the dependency will align.
Firmware updater wants >=3.5, OctoPrint wants <=3.4 in 1.4.0. This was updated in 1.5.0.
Hi Charlie,
That is what I'm trying to do and that's when the error occurs. I'm now getting the following:-
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-dc_Ar8/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython
cwd: None
Complete output (24 lines):
File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
"main", fname, loader, pkg_name)
File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/home/pi/oprint/lib/python2.7/site-packages/pip/main.py", line 16, in
from pip._internal.main import main as _main # isort:skip # noqa
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/main.py", line 13, in
from pip._internal.cli.autocompletion import autocomplete
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/autocompletion.py", line 11, in
from pip._internal.cli.main_parser import create_main_parser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in
from pip._internal.cli import cmdoptions
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/cmdoptions.py", line 25, in
from pip._internal.locations import USER_CACHE_DIR, get_src_prefix
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/locations.py", line 18, in
from pip._internal.utils import appdirs
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/appdirs.py", line 16, in
from pip._internal.utils.compat import WINDOWS, expanduser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/compat.py", line 17, in
from pip._vendor.urllib3.util import IS_PYOPENSSL
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_vendor/urllib3/init.py", line 21, in
from logging import NullHandler
ImportError: cannot import name NullHandler
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-dc_Ar8/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython Check the logs for full command output.
Sorted now - burned a new image using the latest version and all is well.
Many thanks,
Paul.
