I have a strange Issue when I try to connect to Octoprint that is connected via Wifi Connection only.
No connection can be established.
I have assigned a fixed IP for the LAN Connection of Octoprint and another one for the Wifi Connection. Octoprint, in the latest version, runs in a Pi 3B+.
I can see in my Router that the Wifi and LAN Connection is established and I can ping both of them when the LAN Cable is attached.
I can also open the Octorpint UI via both fixed IP-Addresses (Octoprint.local doesnt work anymore since I have updated to the latest Version)
As soon as I disconnect the LAN Cable both IPs cant be pinged anymore (one is obvious) and the Web UI doesnt work anymore, even I can see in the Router the Wifi Connection to the Pi is still established.
My thinking was the Wifi Signal not strong enough so Im thinking to add a USB Wifi Antenna that will be routed outside of the metal Electronics Cabinet. But even with open Cabinet it doesnt work.
octoprint.log (389.3 KB)
serial.log (148 Bytes)
