When I started I had 3 instances of octopi and I could connect to the first two. Then I changed the port and host and eventually got to connect to the second one. When starting the third one, I could connect but after ~20 seconds it would go offline. I changed the port and host again. After this I was no longer able to connect to the second or thrid instacne but, they stayed online for multiple hours untill I had to tuen off the raspberry pi 3B+. This is the command I to change the IP and host for the second and third:
sudo sed s/127.0.0.1/0.0.0.2/ < octoprint.service | sed s/5000/5002/ | sed s/--port=${PORT}/--port=${PORT}\ --basedir=\/home\/pi\/.octoprint2/ > octoprint2.service
sudo sed s/127.0.0.1/127.0.0.3/ < octoprint.service | sed s/5000/5003/ | sed s/--port=${PORT}/--port=${PORT}\ --basedir=\/home\/pi\/.octoprint3/ > octoprint3.service
One weird thing I noticed was If you put in The IP of the raspberry Pi (and no port) It will bring you to the page for the first instance. If you put in the IP:5000 (The port the first instance is on) It will say it refused to connect which is the error the other two give me as well.
If anyone has any Ideas It would be amazing, I've been trying to do this for a month or so and any help/ Ideas would be so so great.
I.. fittled? with the Host and Port
How do you do that without being able to access the UI?
octoprint-systeminfo-20220802115705.zip (87.4 KB)
I am using raspberry pi 3B+, If anyone knows about Netowrking and such I am doing this at school so they might have something not allowing it through, I'm not sure, If anyone knew how to check that It would be amazing.
