After upgrading octoprint from 1.4.x to 1.5.1, print jobs will no longer start. Octoprint runs just fine, says it is starting, but it doesn't heat up either bed or nozzle. Controls on printer control page will set target temperatures for each and they do get and hold set point, but job just sits there for over an hour before I cancel it.
Rebooted Raspberry PI 3B Plus and printer and reloaded web page. Same result. Verified that I can run the print job on the printer directly (successful) and through the printers web interface (successful). Reviewed octoprint settings page (cursory as it was getting late) and didn't find obvious issues.
Not at this time, but will after posting this.[octoprint.log|attachment]
Complete Logs
octoprint.log (2.8 MB)
serial.log (148 Bytes)
Octoprint 1.51
OctoPi Version 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Cetus3D MkII extended running TinyFAB CPU on TinyFab main board
UCTronics 3.5" HDMI touch screen with OctoDash v2.12
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:83.0) Gecko/20100101 Firefox/83.0
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 970825728
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.1
