I hade some problem using octopi, i lost connection all time. I have just install mesh at my house.
so i did a new install on the SD card, and using cabel insted. But the same its just connect for a few min and the drop out
Connected to: Serial<id=0x6d1a3bf0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: start
Send: N0 M110 N0125
Recv: ;S
Recv: ;S
Recv: ;S
Recv: ;S
Recv: ;S
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Connection closed, closing down monito
From the octoprint.log file you posted, in the zip, the octopi server in unable to connect to your printer, so you need to fix that first, it may help if you enable serial logging to get a better idea of what is failing.
