First off all, I am not an youngster and completly new with using Raspberry Pi. So sorry if I look dumb, doing the best I can to keep up.
After putting the image on a USB I get this error (see pic) I connected a monitor to see what was happening and found out I get an error. This took me a whole day btw
I understand some of you might sigh looking at my piost, but your help would be much appreciated.
I used 2 diffrent usb cards end two different programms to install the image. Balena Etcher and Raspberry Pi Imager. I did the whole procedure at least 10 times
I donl;t know how to do that
Don't know
Complete Logs
2019-09-26 OCTOPI-Buster-Lite-0.17.0.img, Crealty Ender 3, Windows 10,
[quote]# Recommended: Notepad++, VSCode, Atom, SublimeText.
!!!!! HEADS-UP MACOSX USERS !!!!!
If you use Textedit to edit this file make sure to use "plain text format"
and "disable smart quotes" in "Textedit > Preferences", otherwise Textedit
will use none-compatible characters and your network configuration won't
work!
WPA/WPA2 secured
#network={
ssid="De Imkerij"
psk="zegikniet"
Open/unsecured
#network={
ssid="put SSID here"
key_mgmt=NONE
WEP "secured"
WEP can be cracked within minutes. If your network is still relying on this
encryption scheme you should seriously consider to update your network ASAP.
#network={
key_mgmt=NONE
wep_key0="put password here"
wep_tx_keyidx=0
Uncomment the country your Pi is in to activate Wifi in RaspberryPi 3 B+ and above
For full list see: https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2
country=NL # The Netherlands
#country=CA # Canada
#country=DE # Germany
#country=FR # France
#country=US # United States
You should not have to change the lines below
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
[/quote]
