When I have a power outage (or when I don't run it off preperly) on by raspberry 4B, I have often "Kernel Panic" not syncing: VFS: Unable to mount root fs on unkwown-block...
I have 3 questions :
- How to fix when you are in this situation
- Is there a possibility of installation that avoids this situation?
- Where are the folders and files to recover on the SD card to keep the configuration and the data to put them back on another SD card?
I have tried with several SD card, same problem.
Impossible
N.A.
I have installed my SD card from Raspberry Pi Imager...
