So, the notorious BLT...
I managed to install and it was running perfect, printed a few files flawlessly until...it started to give all kinds of errors. Tried everything I could find online. If I keep on re-doing everything eventually I can get it to print once, then I start getting errors before the print starts.
Issues:
- Probe starts blinking during bed leveling prior to printing
- Sometimes will not stop on Z axis and hit the bed
- LCD Killed Printer halted please reset error
- LCD Homing error please reset (something like this)
The thing that I cant understand is how can it go from working to not working by itself?? I mean, you either did it right or wrong, so it works or it doesnt. All the posts I read were people trying to get it to work for the first time. I mean, if the cables were wrong it wouldnt work, if the firmware was wrong it wouldnt work.
Wont finish probing without error before printing.
Checked the wires 300 times, re-did the connections, soldered, heat shrunk and hot-glued. Re-installed the firmware a dozen of times. Ran with/without SDcard. Switched USB cable.
No.
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1.1 Safari/605.1.15
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 1903988736
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
Terminal:
Recv: echo:busy: processing
Recv: TT::245.00245.00 //245.00245.00 BB::100.00100.00 //100.00100.00 @@::9191 BB@@::7777
Recv:
Recv: Error:Probing Failed
Changing monitoring state from "Printing" to "Error"
Send: M112
Send: N11 M11217
Send: N12 M104 T0 S018
Send: N13 M140 S087
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xab530d30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0*125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Octoprint Version 1.6.1
Ender 3 Pro
Mainboard 4.2.2
Firmware Ender-3 Pro- Marlin2.0.1 - V1.1.2 - BLTouch.bin (downloaded from creality)
BLTouch ANTCLABS V3.1 from creality
Check pics for cable setup:
Let me know if I can give you any other information.
Please help, I use this printer for work. Thank you very much.
