Killed: PRINTER HALTED Please Reset
Total noob to octoprint, I am trying to connect my ender 3 pro but it keeps saying "Killed: PRINTER HALTED Please Reset"
I already tried looking for the rest command or something but can't seem to find it, I've also shut off my printer and have restarted octoprint
Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x6b63d9b0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: M112
Send: N1 M112*32
Send: N2 M104 T0 S0*35
Send: N3 M140 S0*102
Closing serial port due to emergency stop M112.
Handshake attempt #2 with timeout 2.0s
Changing monitoring state from "Detecting serial connection" to "Offline (Error: Closing serial port due to emergency stop M112.)"
Closing down send loop
Connected to: Serial<id=0x67d24930, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: ok
Changing monitoring state from "Detecting serial connection" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:V1.0 MACHINE_TYPE:Ender-3 Pro EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:BUILD_PERCENT:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: Cap:PROMPT_SUPPORT:0
Recv: Cap:AUTOREPORT_SD_STATUS:0
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: ok
Send: M21
Recv: echo:SD card ok
Recv: ok
Send: M420V1
Recv: echo:Unknown command: "M420V1"
Recv: ok
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M140 S0*97
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Operational" to "Error: Printer halted. kill() called!"
Send: M112
Send: N5 M112*36
Send: N6 M104 T0 S0*39
Send: N7 M140 S0*98
Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
For some reason one of the first things you're sending to your printer is M112 which is the gcode for emergency stop
Also there is a space missing in the M420 V1 gcode.
I guess there is something wrong in the gcode you're trying to print.
@PrintedWeezl All am doing tho is connecting the printer to octoprint and it tells me to reset, do you know what to reset and how to reset it?
Well if a M112 was sent to the printer it has to be power cycled -> turned off and back on again.
I just don't get why it was sent in the first place.
Did you try safe mode? Maybe a plugin is doing something weird
Yes, I did and it seems to work.
I had a plugin called "Emergency Stop Simplified." IN plugin by imputing "-1" it disabled the plugin and allowing me to use my other plugins.
For anyone else running into this issue. My error was coming from a checksum. When I had the serial connections on "AUTO" it failed. When I manually set them to the correct port and 115200 baud it worked no problem. Don't know why but it works
