I've few issues, but at the top of the list is I cannot workout how to produce the SD card Klipper bin file within the Octoprint environment.
As I'm trying to use a MKS Robin Nano V3.1 board I have to use the SD option to put the firmware on.
I have octoprint installed and updated (Using Octo4a on android)
OctoKlipper is installed.
The Printer config is correct for my setup.
I've tried to use the make menuconfig command, but I don't know where to use this. I've tried SSH which works otherwise. The terminal tab in Octoprint is gray'ed out!
octoprint-systeminfo-20260204142633.zip (30.7 KB)
