β OctoPrint octoprint serve
2022-11-22 13:54:35,551 - octoprint.startup - INFO - ******************************************************************************
2022-11-22 13:54:35,552 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2022-11-22 13:54:35,552 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2022-11-22 13:54:35,552 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2022-11-22 13:54:35,553 - octoprint.startup - INFO - ******************************************************************************
2022-11-22 13:54:36,101 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-11-22 13:54:36,101 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-11-22 13:54:36,101 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-11-22 13:54:36,105 - octoprint.plugin.core - INFO - Loading plugins from /Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins, /Users/mfrost/Library/Application Support/OctoPrint/plugins and installed plugin packages...
2022-11-22 13:54:38,462 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugin/core.py", line 1274, in _import_plugin
module = _load_module(module_name, spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugin/core.py", line 52, in _load_module
return imp.load_module(name, f, filename, details)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/vendor/imp.py", line 238, in load_module
return load_package(name, filename)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/vendor/imp.py", line 212, in load_package
return _load(spec)
File "<frozen importlib._bootstrap>", line 721, in _load
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/announcements/__init__.py", line 22, in <module>
from octoprint.server.util.flask import (
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/server/__init__.py", line 46, in <module>
from octoprint.server import util
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/server/util/__init__.py", line 21, in <module>
from . import flask, sockjs, tornado, watchdog # noqa: F401
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/server/util/flask.py", line 34, in <module>
import octoprint.access.users
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/access/users.py", line 11, in <module>
import wrapt
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/wrapt/__init__.py", line 10, in <module>
from .decorators import (adapter_factory, AdapterFactory, decorator,
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/wrapt/decorators.py", line 34, in <module>
from inspect import ismethod, isclass, formatargspec
ImportError: cannot import name 'formatargspec' from 'inspect' (/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/inspect.py)
2022-11-22 13:54:38,732 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
return _load(spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 24, in <module>
from octoprint.server import BRANCH, NO_CONTENT, REVISION, VERSION
import wrapt
2022-11-22 13:54:38,913 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
return _load(spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 29, in <module>
from octoprint.server import safe_mode
import wrapt
2022-11-22 13:54:39,057 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
return _load(spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/appkeys/__init__.py", line 12, in <module>
from octoprint.server import NO_CONTENT, admin_permission, current_user
import wrapt
2022-11-22 13:54:39,171 - octoprint.plugin.core - ERROR - Error loading plugin backup
return _load(spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/backup/__init__.py", line 8, in <module>
import wrapt
2022-11-22 13:54:39,327 - octoprint.plugin.core - ERROR - Error loading plugin logging
return _load(spec)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/plugins/logging/__init__.py", line 14, in <module>
import wrapt
2022-11-22 13:54:39,437 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2022.6.13) did not pass check, not loading.
2022-11-22 13:54:39,774 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 15 hook handlers
2022-11-22 13:54:39,879 - octoprint.cli.server - ERROR - Uncaught exception
File "/Users/mfrost/OctoPrint/venv/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/__init__.py", line 936, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/cli/server.py", line 317, in serve_command
run_server(
File "/Users/mfrost/OctoPrint/venv/lib/python3.11/site-packages/octoprint/cli/server.py", line 145, in run_server
from octoprint.server import CannotStartServerException, Server
import wrapt
