I have an issue where I will start a print on the Ender 3 pro via octoprint (running on a raspberry pi 3 B+) and the print will have a heavy lean in both the x and y axis. I did all the normal tweaking of my x and y belts and there are no issues. I discovered that if I reboot the pi, it solves the issue for probably a day or so, then it reoccurs.
The Ender 3 pro is stock except for using a Bigtree skr mini main board, BLTouch and running Marlin 2.0 bugfix compiled. Raspberry pi is stock and the software is installed via the approach dictated on the octoprint website. Seemingly this is coming from the octoprint software, or the raspberry pi itself.
I am ok with rebooting the pi, but is there a better solution to this?
I will give that a try next time before I do a reboot to see if it is the root cause. Unless it makes me do a reboot... hahaha. Also, maybe I will do a octopi restart instead of the whole pi, see if it is localized to the process.
That's layer slip.
Reinstall Octoprint using the OctoPi image, I had problems with layer slipping from another plug-in. Disable all the plug-ins. Then try again.
If rebooting the Pi cures it, have you replaced the Pi?
What are the settings in your slicer and does that match the printer?.
I have a Pi and an Ender 3 Pro with an SKRminiE3 and it doesn't do that - but I do have 'stock' SKR firmware loaded off BTT's Github, without BL-touch.
