Hello,
When Iam printing on my Anycubic Vyper, and its dark outside its annoying because the webcam is only recording black. So i have to paste in the command MS355 in the terminal, that the nozzle led goes on, so i would like to create a button with that pastes in the command automaticly. But i didnt found a way to adjust the ui, without plugins. How can i do this
Click the wrench on the top
Click on "gcodes" on the left.
find "on printer connection"
Add MS355
-JC
you can do this with custom controls.
https://docs.octoprint.org/en/master/configuration/config_yaml.html#controls
Or use the OctoPrint Gcode Scripts:
this is a good idea too, but might recommend before print job starts for that command and then add whatever gcode to turn it off in after print job completes.
