Hi. I have a Sapphire-S Printer with one of these very ugly LEDGE-X boards. Connecting Octoprint is possible but ist not realy useful because of the closed source firmware a.s.o..
BUT: I want to use Octoprint to Monitor the Printer and transfer Files to the printers SD card.
The Firmware supports filetransfer but it is not working on octoprint.
Is there a chance to get this working?
Connect Octoprint to the Printer, Enabled SD Support
Octoprint 1.3.11
Octopi: Version 0.15.1, running on Raspberry Pi 3 Model B Rev 1.2
Printer: Sapphire-S CoreXY with LERDGE-X Board
Firmware: 3.0.1
Output:
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x67af7910, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: echo:Unknown command: "N0 M110 N0"
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME: Lerdge X 3D
Recv: FIRMWARE_VERSION: V3.0.1
Recv: FIRMWARE_URL: www.lerdge.com
Recv: MACHINE_TYPE: FDM:Corexy
Recv: HOTEND_NUMBER: 1
Recv: EXTRUDER_NUMBER: 1
Recv: HOTEND 1 MAX T: 250.000
Recv: ok
Send: M21
Recv: ok
Recv: echo: SD card init OK
Recv: echo: USB disk init OK
Send: M105
Recv: echo: T:21.2 /0.0 B:28.7 /60.0
Recv: ok
Send: M105
Recv: echo: T:21.4 /0.0 B:29.7 /60.0
Recv: ok
Send: M105
Recv: echo: T:21.2 /0.0 B:30.1 /60.0
Recv: ok
