Let Yi dome camera streaming properly
Yi dome 1080p camera
Not streaming properly
I activate the RTSP
Octopi last version on Raspberry Pi 4
Hi everyone, as I wrote is there a way to let this IP camera working properly?
Thanks in advance
Steve
Hello @stevetriple !
Any logs you have been asked for?
Search this forum for RTSP, there are loads of discussions on the topic and how you can achieve this, but it will require an external software to reencode the stream to html mjpg format.
Hi, this is the log I found
Feb 25 19:11:43 octopi mjpg_streamer[8645]: MJPG-streamer [8645]: Format............: YUYV
Feb 25 19:11:43 octopi mjpg_streamer[8645]: MJPG-streamer [8645]: JPEG Quality......: 80
Feb 25 19:11:43 octopi mjpg_streamer[8645]: MJPG-streamer [8645]: TV-Norm...........: DEFAULT
Feb 25 19:11:43 octopi mjpg_streamer[8645]: MJPG-streamer [8645]: init_VideoIn failed
Feb 25 19:11:44 octopi systemd[1]: webcamd.service: Succeeded.
Feb 25 19:11:44 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:45 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Feb 25 19:11:45 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 284.
Feb 25 19:11:45 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:45 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Feb 25 19:11:45 octopi root[8670]: Starting USB webcam
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: starting application
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: Using V4L2 device.: /dev/video10
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: Desired Resolution: 1920 x 1080
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: Frames Per Second.: 20
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: Format............: YUYV
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: JPEG Quality......: 80
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: TV-Norm...........: DEFAULT
Feb 25 19:11:45 octopi mjpg_streamer[8671]: MJPG-streamer [8671]: init_VideoIn failed
Feb 25 19:11:46 octopi systemd[1]: webcamd.service: Succeeded.
Feb 25 19:11:46 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:47 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Feb 25 19:11:47 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 285.
Feb 25 19:11:47 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:47 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Feb 25 19:11:48 octopi root[8696]: Starting USB webcam
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: starting application
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: Using V4L2 device.: /dev/video10
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: Desired Resolution: 1920 x 1080
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: Frames Per Second.: 20
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: Format............: YUYV
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: JPEG Quality......: 80
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: TV-Norm...........: DEFAULT
Feb 25 19:11:48 octopi mjpg_streamer[8697]: MJPG-streamer [8697]: init_VideoIn failed
Feb 25 19:11:49 octopi systemd[1]: webcamd.service: Succeeded.
Feb 25 19:11:49 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:50 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Feb 25 19:11:50 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 286.
Feb 25 19:11:50 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Feb 25 19:11:50 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Feb 25 19:11:50 octopi root[8722]: Starting USB webcam
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: starting application
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: Using V4L2 device.: /dev/video10
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: Desired Resolution: 1920 x 1080
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: Frames Per Second.: 20
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: Format............: YUYV
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: JPEG Quality......: 80
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: TV-Norm...........: DEFAULT
Feb 25 19:11:50 octopi mjpg_streamer[8723]: MJPG-streamer [8723]: init_VideoIn failed
Feb 25 19:11:51 octopi systemd[1]: webcamd.service: Succeeded.
Feb 25 19:11:51 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
I'm searching for something not overloading my CPU like a transcoding usually does, if it's possible
It's not that easy, think of it like this - you are allergic to some food, you can't eat it, but you don't want to buy the slightly more expensive food you are not allergic to, yet you still want the food.
There's lots of topics on RTSP streaming, OctoPrint only natively supports mjpg and HLS webcam streaming, anything else does not work.
