I am trying to connect an old USB "LifeCam VX-3000" camera to my Raspberry Pi 3,2,
I have updated /root/bin/webcamd to have:
camera_usb_options="-r 640x480 -f 10 -y"
But I still get This error in the /var/log/webcamd.log Log:
logger: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r VGA -f 10
MJPG Streamer Version.: 2.0
i: Frames Per Second.: 10
i: Format............: JPEG
i: Could not obtain the requested pixelformat: MJPG , driver gave us: JPEG
... will try to handle this by checking against supported formats.
i: init_VideoIn failed
Here is my Camera:
pi@Octopi-CR10:~ $ lsusb
Bus 001 Device 004: ID 045e:00f5 Microsoft Corp. LifeCam VX-3000
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Ive had similar issues with life-cams and mjpg_streamer tho my octoprint is on a box running MX16 which is a debian-based so should be similiar.
first just make sure your webcam is actually at /dev/video0 by running
ls /dev/video0
so long it is there than you can
check for uvcvideo
modprobe uvcvideo
so long it is there than you can try to
sudo service webcamd restart
and if still nothing good happening. you can attempt to manually start mjpg from the prompt by issuing the command yourself and this is where with a lil patience you can get it to work most the time. start by changing the flags a bit each time you reissue the command. (using up arrow to make it quicker)
You can notice subtle changes to each command if one of those commands works you can <ctrl> + <c> too kill it and than make the changes too the webcamd config file accordingly.
for instance my lifecam 1000 runs well with this command
and basically someone might be able to pinpoint your issue quickly because of some luck but mjpg_streamer in my opinion it was quicker for me to solve my camera issues by running the command mutiple times with different flags until one worked and than i made the changes too the webcamd config file accordingly.
