Hmm. Well, SSH wasn't working until I disabled the firewall, so I'm guessing it was blocking that too. I haven't had time to tinker with it recently but I hope to this weekend.
You can try reaching the normal hostname from your windows box .. just octopi or adding an entry to the hosts file as suggested above if that doesn't work. You may want to configure that box to have a static IP. You would do that from whatever is running your DHCP (e.g. your router).
Honestly, I don't have a problem using the IP address.
