SUPER Edit... thanks to Phizicks from an awesome DIY discord...
no sure if nano is installed. try
nano /home/pi/oprint//lib/python2.7/site-packages/octoprint/templates/tabs/file control.jinja2
then press CTRL+W and type control-xyhome and press enter. it should show where it is on the page.
easiest thing to do is delete that line
then press CTRL+X to exit and save when it asks you
EDIT...so i found the location of the file but that location does not give me a way to disable it.
Is there a way to disable the home command button in the x/y and z menu?
I need to edit the button command as my machine does not have endstops
What did you already try to solve it?/// i made custom commands to help
Logs none... i am trying to disable the sending of the command for the homing command...
I use with cnc, it works great as it is marlin based but big fingers, touch screen and watching the machine, i some times hit the home button and small movements cause crash, nema 23 can generate a lot of power...
CB
