It appears as if the Logging-plugin can't find any available loggers to use. The Logging plugin itself is enabled, I can see the 'Logging' section in the configuration menu, however the dropdown that (I assume) is supposed to contain all channels of information that can potentially be logged is empty.
I tried to disable / and re-enable the Logging plugin itself, but that did not make a difference. Earlier, my setup was running on a Raspberry Pi using OctoPi when this occured. Now I have moved to a different setup running on a Radxa Rock Pi 4B Plus which runs the DietPi linux disto with Octoprint installed using DietPi's built-in software feature to which I have restored the back-up of my Raspberry setup, but still having the same problem. Otherwise Octoprint seems to work properly and I have no problems during prints or anything.
Yes, in safe mode the same behaviour is present on the logging configuration page.
No.
octoprint-systeminfo-20250223224458.zip (28.6 KB)
- OctoPrint 1.10.3
- Python 3.11.2
The Errors in the SystemInfo bundle seem to indicate an error when trying to load/process the Logger plugin:
2025-02-23 22:44:55,188 - octoprint - ERROR - Exception on /plugin/logging/ [GET] Traceback (most recent call last): File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/flask/app.py", line 2529, in wsgi_app response = self.full_dispatch_request() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/flask/app.py", line 1825, in full_dispatch_request rv = self.handle_user_exception(e) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/flask/app.py", line 1823, in full_dispatch_request rv = self.dispatch_request() ^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/flask/app.py", line 1799, in dispatch_request return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/octoprint/server/util/flask.py", line 1646, in decorated_view return func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/octoprint/access/permissions.py", line 175, in _decorated rv = f(*args, **kw) ^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/octoprint/plugins/logging/__init__.py", line 48, in get_all levels = self._get_logging_levels() ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/dietpi_userdata/octoprint/.local/lib/python3.11/site-packages/octoprint/plugins/logging/__init__.py", line 193, in _get_logging_levels for key, value in config.get("loggers", {}).items() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'NoneType' object has no attribute 'items'
