Hi Guys ![]()
We are calibrating Linear Delta mechanics with long test essays and we would like to get filtered log messages at the Terminal Console to copy/paste, or better solution.
Can someone recommends a better solution ?
Thanks in advance ![]()
Just search for a way to avoid "too many lines to buffer, cut off" error message, but we could not find any similar use case at the knowledge base.
Not Tried because it does not make sense for this scenario. It is supposed solved by Logging for Terminal configuration for copy/paste or file.
--- too many lines to buffer, cut off ---
Informations to copy/paste from Terminal [octoprint-systeminfo-20240327152859.zip|attachment](upload://4bjwXAS5JUl12ykbKFyMfd9XfQA.zip) (23.7 KB) : ... [...] Recv: Bed X: -3.50 Y: 30.31 Z: -0.84 [...] Recv: Bed X: 14.00 Y: 12.12 Z: -0.26 [...] Recv: Bed X: -24.50 Y: -6.06 Z: 1.01 [...] ...Filters tried: (works good for small essays)
Suppress temperature messages
Suppress SD status messages
Suppress position messages
Suppress wait responses
Suppress processing responses
Supress "Send:"
Supress "Recv: ok"
Supress "Communication"
