I have changed router, but cannot login What did you already try to solve it?
Found the new local ip adress, have set it to fixed.
I get the login screen but can not login,
name and password are correct.
(Moved back to the old router to check and everyting works) Logs (syslog, dmesg, ... no logs, no support)
Trying to connect my two printers to Icotera fiberbox on cabled connections.
local ip for old connection 10.0.0.xxx new conection 192.168.1.xxx
Yes, it is there with the rigth mac adress.
Accessing the adress olso gives me the login screen,
but cannot login, "password or user not correct"
And i have checked it is the correct
Mission succeeded, without new installation.
Removed users.yaml
Put in first run to true, got the opportunity to drop username and password.
move to the new fiber router.
Again set first run to true and access control to true and everything is back to normal for both printers
