The login via haproxy is always rejected.
Tried login in via the url with port 5000. That works.
Tried rebooting the pi.
Octopi on raspberry pi 4. Configured to run 2 instances. If connecting to port 5000 or 5001 I get a login and am able to login. When I use the /a10/ path I also get the same login but it does not work.
I tried enabling http authentication on haproxy. That only adds a http login but when logging in it still stops at the regular login.
