Logitech Brio
I seem to be limited to 1920 x 1080
Edited octopi.txt camera_usb_options-"-r 3840x2160 -f10"
Running the most current versions of octoprint on a raspberry pi 3b+
Is it possible to take 4k timelapse with this setup?
"-r 3840x2160 -f10" would configure the camera to stream 10 jpg images at 3840x2160 through your raspberry pi. That is a LOT of data, probably way too much. If it works, it would probably require a lower framerate.
Is it possible to have 2 resolutions?
A lower res to monitor with and a higher res for snapshots?
Unfortunately, it is not. This is a limitation of camera drivers; switching between resolutions takes a while, so you can't do it while streaming video.
What about using 2 cameras on a single pi? Can I have one at 4K that is only for snapshots and isnโt sending data the whole time?
