Logitech C920
Printer model
Prusa Mk3s+
Logitech C920 and the Prusa Mk3s+does not show up in linux on my PI 3B+.
They both worked a day ago but only in one port. Now it does not work in any port.
I have verified that the webcam works on my Windows PC.
I have verified that lsusb does not report the webcam.
I have tried every port on the PI.
I have restarted between each USB port change.
I have tried leaving the USB plugged in during reboots and leaving it out then plugging in once booted. No Dice.
pi@octopi:~ $ lsusb
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
pi@octopi:~ $ #USB was in when booting. Now un plugging and replugging it.
pi@octopi:~ $ dmesg | tail
[ 18.203626] Bluetooth: HCI UART protocol H4 registered
[ 18.203695] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.203868] Bluetooth: HCI UART protocol Broadcom registered
[ 18.634707] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.634728] Bluetooth: BNEP filters: protocol multicast
[ 18.634746] Bluetooth: BNEP socket layer initialized
[ 18.655586] NET: Registered PF_ALG protocol family
[ 18.688006] cryptd: max_cpu_qlen set to 1000
[ 20.311196] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 33.750795] cam-dummy-reg: disabling
pi@octopi:~ $ #No sign of USB activity
pi@octopi:~ $ lsusb
pi@octopi:~ $ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
pi@octopi:~ $
This is a fresh install of OCtoprint/Octopi using The Instructions Found Here.
OctoPrint version : 1.8.7
OctoPi version : 1.0.0
OctoDash version :0.0.7
Other Plugins:
Cura Thumbnails
DisplayLayerProgress
Filament Manager
Firmware Check
OctoDash Companion
Preheat Button
PrintTimeGenius Plugin
Printer Dialogs
Printer Notifications
Slicer Thumbnails
Spool Manager
Virtual Printer
