Logitech Camera not working any more
Wiggled all the cables and looked at the settings
V 1.38
GNU nano 2.2.6 File: /var/log/webcamd.log
Goodbye...
Starting up webcamDaemon...
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
http options: -w ./www-octopi -n
Camera model 046d:082b is known to not work with -f parameter, stripping it out
logger: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480
MJPG Streamer Version.: 2.0
i: Frames Per Second.: -1
i: Format............: JPEG
o: HTTP Listen Address..: (null)
Goodbye...
Everything worked before without issue any ideas? My flu is making me brain dead!
