ID 046d:0850 Logitech, Inc. QuickCam Web
Camera does not seem to be connecting, or showing up
I edited octopi.txt by adding -y
camera_usb_options="-r 640x480 -f 10 -y"
and rebooted with the camera attached with no luck.
tpi@octopi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:0850 Logitech, Inc. QuickCam Web
Bus 001 Device 003: ID 2b71:0002
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10 -y
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found $
<13>Dec 30 06:07:49 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 $
MJPG Streamer Version: git rev: 85f89a8c321e799fabb1693c5d133f3fb48ee748
i: Frames Per Second.: 10
i: Format............: YUYV
i: JPEG Quality......: 80
i: The specified resolution is unavailable, using: width 356 height 292 instead
i: Could not obtain the requested pixelformat: YUYV , driver gave us: GRBG
... will try to handle this by checking against supported formats.
i: init_VideoIn failed
Goodbye...
Octopi is a fresh install of 0.18.0
any help would be greatly appreciated
