I have a RPI3B running octopi with a Logitech Webcam C270 that have been working flawlessly for 5 years. For reasons I just made a full re-install of octopi (new underlying debian)
The webcam unfortunately seems to have stopped working.
The usb camera is found:
pi@um2:~$ lsusb
Bus 001 Device 007: ID 046d:080c Logitech, Inc.
cat /var/log/webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Apr 24 09:28:25 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Unable to dequeue buffer: No such device
i: Error grabbing frames
i: cleaning up resources allocated by input thread
Unable to stop capture: No such device
Done bringing up all configured video devices
octoprint-systeminfo-20230424093456.zip (27.9 KB)
Webcam stream stuck at loading:
Any help highly appreciated!
