Logitect Communicate STX no stream
Hi I'm trying to get my Logitech Communicate STX(Logitech v-ubk45) to run with Octoprint.
Accordingly to the supported camera list it should work (according the list it worked with pi 4).
I don't get a stream in octoprint.
The only thing where I can see the string is with this URL: "http://octopi.local:8080/?action=stream".
After a long! loading time I get the stream in this window. Moreover this stream is very bad and lagging.
I tried replacing the original stream url with this but that does not work.
The camera is listed correctly in "lsusb" and is set in octopi.txt with following lines:
camera="usb"
camera_usb_options="-r 640x480 -f 10" (I also tried adding "-y" at this line but that didn't help either)
OctoPrint version : 1.4.0
OctoPi version : 0.17.0
Hi. I've got the same Logitech USB camera and want to set it up in OctoPrint. Were you able to get yours to work?
Thanks, Jim
