I recently built a new octopi instance, and while adding my favorite plugins, was not able to find Print History. I searched but didn't find any mention of what happened to it, or if there's a way to install it other than the plugin manager, or if there is a replacement in the works.
Thanks for any info.
Good News and Bad News:
Good: https://github.com/imrahil/OctoPrint-PrintHistory
Bad: Looks like the author has abandoned it.
Booooooo! You are right, that sure is bad news. Thank you very much for the github url. I took that and did a URL load for the plugin. I've yet to print anything and see if it works, but I am hopeful. And in case things go horribly wrong, I took a backup, lol.
Thanks again!
Did it worked? I'm looking for the same plugin bu I want to be sure that it doesnt bring any problems and that it actually works
It is still installed on my system (OctoPi 0.14, OctoPrint 1.3.11) and it still works as well as it always has.
What url are you using? I have tried
and both return
tail plugin_pluginmanager_console.log
2019-11-03 14:01:27,477 > Collecting https://github.com/imrahil/OctoPrint-PrintHistory.git
2019-11-03 14:01:32,598 > Downloading https://github.com/imrahil/OctoPrint-PrintHistory.git
2019-11-03 14:01:32,602 ! Cannot unpack file /tmp/pip-unpack-7mou4y/OctoPrint-PrintHistory.git (downloaded from /tmp/pip-req-build-YrgM2C, content-type: text/html; charset=utf-8); cannot detect archive format
2019-11-03 14:01:32,603 ! Cannot determine archive format of /tmp/pip-req-build-YrgM2C
2019-11-03 14:03:53,558 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/imrahil/OctoPrint-PrintHistory --no-cache-dir
2019-11-03 14:03:58,621 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-11-03 14:03:58,622 > Collecting https://github.com/imrahil/OctoPrint-PrintHistory
2019-11-03 14:04:03,843 > Downloading https://github.com/imrahil/OctoPrint-PrintHistory
2019-11-03 14:04:03,847 ! Cannot unpack file /tmp/pip-unpack-jzgelX/OctoPrint-PrintHistory (downloaded from /tmp/pip-req-build-lfUDRI, content-type: text/html; charset=utf-8); cannot detect archive format
2019-11-03 14:04:03,848 ! Cannot determine archive format of /tmp/pip-req-build-lfUDRI
Hi @anotherjoe ,
the right Url is: https://github.com/imrahil/OctoPrint-PrintHistory/archive/master.zip
BUT, maybe should take a look into this thread:
a release candidate of my new "Job History"-Plugin is out now.
Hopefully most bugs were fixed!
The first release includes just some basic ground features .
But I think the plugin is now well structured with a good fundament.
Next step is testing on different printers/cameras and cleanup the sourcecode.
BR
Olli
BR
Olli
just in time....I was a few minutes into a long print when I read this. I cancelled it, than installed your plugin.
Hey all, just to ping we got OctoPrint-PrintHistory working again
