Looking for USB webcam that will work in a heated enclosure
<Looking for USB webcam that will work in a heated enclosure -->
Looking for USB webcam that will work in a heated enclosure. I normally print PC+CF, which is high temp stuff and requires an enclosure. I have been successfully using a PI B with a PI cam for PETG stuff without the enclosure, but when I stick the PI B with the CAM into the enclosure, the PI doesn't work reliably because of the heat. My idea is to put a webcam into the enclosure and keep the PI outside.
I therefore am looking for an inexpensive webcam that will work with Octoprint inside a heated enclosure.
Any recommendations?
I can't really recommend you a USB cam, but just fyi there are really long ribbon cables you can use for the pi cam.
Another option is a ribbon to HDMI to ribbon adaptor. Those are quite cheap on amazon
I use a Logitech C270 (one of the cheapest) and I print ASA and ABS in enclosure.
