I setup 2 octoprint dockers for 2 printer in rpi4, all are fine when access directly by port (http://localhost:5000 and http://localhost:5001), but when I use haproxy (http://localhost/ce3pro and http://localhost/mtcxy), the login screen is loop infinity
So I believe the issue is the configuration of haproxy
Anyone can help me?
Thanks!
Following is the configuration file of haproxy and docker-compose
haproxy.cfg
global
maxconn 4096
user haproxy
group haproxy
log /dev/log local0 debug
tune.ssl.default-dh-param 2048
defaults
log global
mode http
compression algo gzip
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind :::80 v4v6
#bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
#use_backend ce3pro if { path_beg /ce3pro/ }
use_backend ce3pro if { path /ce3pro } || { path_beg /ce3pro/ }
#use_backend mtcxy if { path_beg /mtcxy/ }
use_backend mtcxy if { path /mtcxy } || { path_beg /mtcxy/ }
use_backend webcam_hls if { path_beg /hls/ }
use_backend webcam_hls if { path_beg /jpeg/ }
default_backend webcam
backend ce3pro
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0
#reqrep ^([^\ :]*)\ /ce3pro/(.*) \1\ /\2
#reqadd X-Scheme:\ https if needs_scheme { ssl_fc }
#reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc }
#reqadd X-Script-Name:\ /ce3pro
http-request replace-path ^([^\ :]*)\ /ce3pro/(.*) \1\ /\2
#http-request replace-path ^([^\ :]*)\ /ce3pro(.*) \1\ /\2
http-request add-header X-Scheme https if needs_scheme { ssl_fc }
http-request add-header X-Scheme http if needs_scheme !{ ssl_fc }
http-request add-header X-Script-Name /ce3pro
option forwardfor
server octprint1 127.0.0.1:5000
errorfile 503 /etc/haproxy/errors/503-no-octoprint.http
backend mtcxy
#reqrep ^([^\ :]*)\ /mtcxy/(.*) \1\ /\2
#reqadd X-Script-Name:\ /mtcxy
#http-request replace-path ^([^\ :]*)\ /mtcxy/(.*) \1\ /\2
http-request replace-path ^([^\ :]*)\ /mtcxy(.*) \1\ /\2
http-request add-header X-Script-Name /mtcxy
option forwardfor
server octprint2 127.0.0.1:5001
backend webcam
#reqrep ^([^\ :]*)\ /webcam/(.*) \1\ /\2
http-request replace-path ^([^\ :]*)\ /webcam/(.*) \1\ /\2
server webcam1 127.0.0.1:8080
backend webcam_hls
server webcam_hls_1 127.0.0.1:28126
errorfile 503 /etc/haproxy/errors/503-no-webcam-hls.http
docker-compose.yml for first printer
version: '2.4'
services:
ce3pro:
container_name: ce3pro
image: octoprint/octoprint
restart: unless-stopped
ports:
- 5000:5000
- 8080:8080
devices:
- /dev/ttyCE3PRO:/dev/ttyUSB0
# - /dev/ttyUSB0:/dev/ttyUSB0
# - /dev/video0:/dev/video0
volumes:
- /root/octoprint/ce3pro:/octoprint
# uncomment the lines below to ensure camera streaming is enabled when
# you add a video device
# environment:
# - ENABLE_MJPG_STREAMER=true
# - CAMERA_DEV=/dev/video0
# - MJPG_STREAMER_INPUT="-y -n -r 1280x960 -f 30
docker-compose.yml for second printer
version: '2.4'
services:
mtcxy:
container_name: mtcxy
ports:
- 5001:5000
- 8081:8080
devices:
- /dev/ttyMTCXY:/dev/ttyUSB0
# - /dev/ttyUSB1:/dev/ttyUSB0
# - /dev/video2:/dev/video0
volumes:
- /root/octoprint/mtcxy:/octoprint
# environment:
