Serial connection drops out almost randomly.
yes, changed power supply, usb cable.
no, it is random.
no
octoprint.log (42.6 KB)
serial.log (740 Bytes)
Ender 3 pro
Octo print Version 1.8.6
Octo Pi Version 0.18.0
It has never lost connection while printing yet, when I notice it is if the bed is heating up and it reaches desired temp it disconnects, I believe it happened once when hotend reached the set temp also. I have the pi 3 setup to run two printers but one is not connected at this time.
sudo nano /etc/udev/rules.d/99-usb.rules
#Tevo3pro
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.3", SYMLINK+="Tevo3pro"
#ender3
SUBSYSTEM=="tty", ATTRS{idVendor}=="0483", ATTRS{idProduct}=="5740", ATTRS{devpath}=="1.5", SYMLINK+="Ender3pro"
I can't duplicate the issue it is random. Based on the logs do ya'll see anything that may lead me to the right direction? I'm wondering if its a voltage issue, I tried swapping the power supply feeding the pi but still have the issue. I will try monitoring voltage and see if I can see it drop out at any point.
2022-12-29 00:31:40,169 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2022-12-29 00:31:40,273 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2022-12-29 00:34:27,399 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 3997, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 6672, in readline
c = self.read(1)
File "/home/pi/oprint/lib/python3.7/site-packages/serial/serialposix.py", line 596, in read
'device reports readiness to read but returned no data '
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2022-12-29 00:34:27,406 - octoprint.util.comm - ERROR - Please see OctoPrint randomly loses connection to the printer with a "SerialException" - FAQ - OctoPrint Community Forum for possible reasons of this.
2022-12-29 00:34:27,425 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline after error"
