I've recently added a new Lulzbot Mini to my toolbox, replacing an older one I recently sold. I did the firmware update/etc via Cura, and I'm noticing a weird behavior with it not wiping the tip properly before leveling.
On first boot, all goes well. Preheat, wipe on pad, level, print. stop/cool is all great. ALL subsequent runs (with same G-Code) have the wipe done ~15mm above the pad, but then it usually continues to level and run properly. I say usually, because sometimes (1 out of 10) it acts like the level didn't work, and it starts spewing at about the same offset (~15mm) above the bed.
I've loaded the latest material profiles I could find from Cura, played with the Z-height (thinking it may be an integer error as it goes to Z-5mm to scrub the tip), tweaked the startup code to ensure I was messing with the right profile, etc. The only thing that ALWAYS works is rebooting the Pi before a print - that scrubs the tip properly. ALL subsequent prints do the "hover" scrub.
I even reloaded a fresh octoprint image to see if that'd solve it. Nope! Analyzing the generated G-Code says it's going to the right Z-height for the scrub, but... it ain't!
Next task is to try to capture the terminal stream to see what's up. In the meanwhile, I thought I'd ask here.
On Octoprint 1.3.8 running OctoPi 0.15.1 on Lulzbot Mini, firmware 1.1.5.64
Thanks,
Dave
