My printer (Qidi XMax) supports M0 as a filament change (I have confirmed this).
However, even though I have removed M0 from the 'Blocked Commands' field it is not being passed through to the printer.
In 'Settings / Serial Connection / Firmware & Protocol' Removed M0 from the 'Blocked Commands' field, removed M0 from the 'Pausing commands' field, added M0 to the 'Long running commands' field.
Yes
Complete Logs
Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x71da9b10, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Repl: M110 N0 -> M110
Send: N0 M110*35
Recv: ok N:0
Changing monitoring state from "Detecting serial connection" to "Operational"
Send: N0 M110*35
Recv: ok N:0
Send: N1 M115*39
Recv: ok CBD make it.Date:Jan 23 2019 Time:14:58:22
Repl: ok CBD make it.Date:Jan 23 2019 Time:14:58:22
-> ok CBD made it, foosel fixed it.Date:Jan 23 2019 Time:14:58:22
Send: N2 M21*18
Recv: //Disk init fail!
Recv: ok N:2
Send: N3 M105*36
Recv: ok T:40 /0 B:43 /0 @:0 B@:0
Send: N4 M105*35
Recv: ok T:39 /0 B:43 /0 @:0 B@:0
Send: N5 M105*34
Send: N6 M105*33
Send: N7 M105*32
Send: N8 M105*47
Send: N9 M105*46
Send: N10 M105*22
Send: N11 M105*23
Recv: ok T:40 /0 B:42 /0 @:0 B@:0
Send: N12 M105*20
Recv: ok T:39 /0 B:42 /0 @:0 B@:0
Send: N13 M105*21
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110*35
Recv: ok N:0
Changing monitoring state from "Starting" to "Printing"
Send: N1 M201 X9000 Y9000 Z500 E10000*59
Recv: ok N:1
Send: N2 M203 X500 Y500 Z12 E120*14
Recv: ok N:2
Send: N3 M204 P1500 R1500 T1500*84
Recv: ok N:3
Send: N4 M205 X10.00 Y10.00 Z0.20 E2.50*59
Recv: ok N:4
Send: N5 M205 S0 T0*38
Recv: ok N:5
Send: N6 M107*35
Recv: ok N:6
Send: N7 M140 S100*99
Recv: ok N:7
Send: N8 M104 S240*107
Recv: ok N:8
Send: N9 G92 A0 B0*24
Recv: ok N:9
Repl: G28 X0 Y0 -> G28 X0 Y0
Send: N10 G28 X0 Y0*35
Recv: wait
Repl: wait -> echo:busy processing
Recv: ok N:10
Send: N11 G0 X-1000 Y-1000 F1800*119
Recv: ok N:11
Repl: G28 Z0 -> G28 Z0
Send: N12 G28 Z0*106
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: ok N:12
Send: N13 G1 X0 Y0 Z50 F3600*7
Recv: ok N:13
Send: N14 G1 X0 Y0 F3600*127
Recv: ok N:14
Send: N15 G92 E0*115
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: ok N:15
Send: N16 M105*16
Recv: ok T:108 /240 B:53 /100 @:128 B@:128
Send: N17 G92 A0 B0*39
Recv: ok N:17
Send: N18 G1 Z0.200 F12000.000*12
Recv: ok N:18
Send: N19 M109 S240*86
Recv: T:109 E:0 B:53
Recv: wait
Recv: T:110 E:0 B:53
Recv: wait
Recv: T:113 E:0 B:53
Recv: T:115 E:0 B:53
Recv: wait
Recv: T:117 E:0 B:53
Recv: T:118 E:0 B:54
Recv: wait
Recv: T:121 E:0 B:54
Recv: wait
Recv: T:122 E:0 B:54
Recv: T:124 E:0 B:54
Recv: wait
Recv: T:126 E:0 B:55
Recv: T:128 E:0 B:55
Recv: wait
Recv: T:130 E:0 B:55
Recv: wait
Recv: T:132 E:0 B:55
Recv: T:133 E:0 B:56
Recv: wait
Recv: T:135 E:0 B:56
Recv: T:137 E:0 B:56
Recv: wait
Recv: T:138 E:0 B:56
Recv: wait
Recv: T:140 E:0 B:56
Recv: T:142 E:0 B:56
Recv: wait
Recv: T:144 E:0 B:57
Recv: T:146 E:0 B:57
Recv: wait
Recv: wait
Recv: T:149 E:0 B:57
Recv: T:150 E:0 B:58
Recv: wait
Recv: T:152 E:0 B:58
Recv: T:153 E:0 B:58
Recv: wait
Recv: T:155 E:0 B:58
Recv: T:157 E:0 B:58
Recv: wait
Recv: T:158 E:0 B:58
Recv: wait
Recv: T:160 E:0 B:59
Recv: T:161 E:0 B:59
Recv: wait
Recv: T:162 E:0 B:59
Recv: T:163 E:0 B:59
Recv: wait
Recv: T:165 E:0 B:60
Recv: wait
Recv: T:167 E:0 B:60
Recv: T:168 E:0 B:60
Recv: wait
Recv: T:170 E:0 B:60
Recv: T:171 E:0 B:60
Recv: wait
Recv: T:172 E:0 B:60
Recv: wait
Recv: T:173 E:0 B:61
Recv: T:175 E:0 B:61
Recv: wait
Recv: T:176 E:0 B:61
Recv: T:177 E:0 B:61
Recv: wait
Recv: T:179 E:0 B:61
Recv: wait
Recv: T:180 E:0 B:62
Recv: T:182 E:0 B:62
Recv: wait
Recv: T:183 E:0 B:62
Recv: wait
Recv: T:185 E:0 B:62
Recv: wait
Recv: T:187 E:0 B:63
Recv: wait
Recv: T:189 E:0 B:63
Recv: T:190 E:0 B:63
Recv: wait
Recv: T:192 E:0 B:63
Recv: wait
Recv: T:193 E:0 B:63
Recv: T:193 E:0 B:64
Recv: wait
Recv: T:195 E:0 B:64
Recv: T:196 E:0 B:64
Recv: wait
Recv: wait
Recv: T:197 E:0 B:64
Recv: T:198 E:0 B:65
Recv: wait
Recv: T:200 E:0 B:65
Recv: T:201 E:0 B:65
Recv: wait
Recv: T:202 E:0 B:65
Recv: wait
Recv: T:203 E:0 B:65
Recv: T:204 E:0 B:66
Recv: wait
Recv: T:205 E:0 B:66
Recv: T:206 E:0 B:66
Recv: wait
Recv: T:207 E:0 B:66
Recv: wait
Recv: T:208 E:0 B:66
Recv: T:210 E:0 B:66
Recv: wait
Recv: T:210 E:0 B:67
Recv: T:211 E:0 B:67
Recv: wait
Recv: T:212 E:0 B:67
Recv: wait
Recv: T:213 E:0 B:67
Recv: T:214 E:0 B:67
Recv: wait
Recv: T:215 E:0 B:67
Recv: T:216 E:0 B:68
Recv: wait
Recv: T:217 E:0 B:68
Recv: wait
Recv: T:218 E:0 B:68
Recv: T:219 E:0 B:68
Recv: wait
Recv: T:220 E:0 B:68
Recv: T:221 E:0 B:68
Recv: wait
Recv: T:221 E:0 B:69
Recv: wait
Recv: T:223 E:0 B:69
Recv: wait
Recv: T:224 E:0 B:69
Recv: wait
Recv: T:226 E:0 B:69
Recv: wait
Recv: T:226 E:0 B:70
Recv: T:227 E:0 B:70
Recv: wait
Recv: T:228 E:0 B:70
Recv: T:229 E:0 B:70
Recv: wait
Recv: T:230 E:0 B:70
Recv: T:231 E:0 B:71
Recv: wait
Recv: wait
Recv: T:232 E:0 B:71
Recv: T:233 E:0 B:71
Recv: wait
Recv: wait
Recv: T:234 E:0 B:72
Recv: wait
Recv: T:233 E:0 B:72
Recv: wait
Recv: T:235 E:0 B:72
Recv: wait
Recv: wait
Recv: T:234 E:0 B:73
Recv: wait
Recv: wait
Recv: wait
Recv: T:235 E:0 B:73
Recv: T:235 E:0 B:74
Recv: wait
Recv: wait
Recv: wait
Recv: T:236 E:0 B:74
Recv: ok N:19
Send: N20 M190 S100*91
Recv: T:237 E:0 B:74
Recv: wait
Recv: T:237 E:0 B:75
Recv: wait
Recv: wait
Recv: T:238 E:0 B:75
Recv: wait
Recv: T:239 E:0 B:76
Recv: wait
Recv: wait
Recv: T:240 E:0 B:76
Recv: wait
Recv: wait
Recv: T:241 E:0 B:76
Recv: wait
Recv: T:241 E:0 B:77
Recv: wait
Recv: wait
Recv: T:240 E:0 B:77
Recv: wait
Recv: wait
Recv: T:241 E:0 B:78
Recv: T:240 E:0 B:78
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:79
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:80
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:241 E:0 B:81
Recv: wait
Recv: T:240 E:0 B:81
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:82
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:83
Recv: wait
Recv: T:239 E:0 B:83
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:84
Recv: wait
Recv: wait
Recv: T:239 E:0 B:84
Recv: wait
Recv: wait
Recv: T:240 E:0 B:85
Recv: wait
Recv: wait
Recv: T:239 E:0 B:85
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:86
Recv: T:239 E:0 B:86
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:87
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:239 E:0 B:88
Recv: T:240 E:0 B:88
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:89
Recv: T:239 E:0 B:89
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:90
Recv: wait
Recv: T:239 E:0 B:90
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:91
Recv: wait
Recv: T:239 E:0 B:91
Recv: wait
Recv: wait
Recv: T:240 E:0 B:92
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:239 E:0 B:93
Recv: wait
Recv: T:240 E:0 B:93
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:94
Recv: wait
Recv: T:239 E:0 B:94
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:239 E:0 B:95
Recv: wait
Recv: wait
Recv: T:240 E:0 B:95
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:240 E:0 B:96
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: T:239 E:0 B:96
Recv: ok N:20
Send: N21 G0 X0 Y4 Z0.3 F3600*43
Recv: ok N:21
Send: N22 G1 X250 Y5 F2400*123
Recv: ok N:22
Send: N23 G1 X5 A19 F2400*93
Recv: ok N:23
Send: N24 G92 A0 B0*39
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: ok N:24
Send: N25 M105*16
Recv: ok T:240 /240 B:97 /100 @:87 B@:128
Send: N26 G1 X5 F2400*49
Recv: ok N:26
Send: N27 G21*47
Recv: ok N:27
Send: N28 G90*42
Recv: ok N:28
Send: N29 M82*34
Recv: ok N:29
Send: N30 G92 E0*116
Recv: ok N:30
Send: N31 M900 K0.2*95
Recv: //Unknown opt: K 0x4b index:9 len:17,line:2447,s:N31 M900 K0.2*95
Recv:
Recv: //Unknown opt: 0 0x30 index:10 len:17,line:2447,s:N31 M900 K0.2*95
Recv:
Recv: //Unknown opt: . 0x2e index:11 len:17,line:2447,s:N31 M900 K0.2*95
Recv:
Recv: //Unknown opt: 2 0x32 index:12 len:17,line:2447,s:N31 M900 K0.2*95
Recv:
Recv: ok N:31
Send: N32 G1 Z0.200 F12000.000*4
Recv: ok N:32
Send: N33 G1 E-2.70000 F1800.000*10
Recv: ok N:33
Send: N34 G92 E0*112
Recv: ok N:34
Send: N35 G1 X149.410 Y120.410 F12000.000*91
Recv: ok N:35
Send: N36 G1 E2.70000 F1800.000*34
Recv: ok N:36
Send: N37 G1 F900*67
Recv: ok N:37
Send: N38 G1 X150.590 Y120.410 E2.77625*84
Recv: ok N:38
Send: N39 G1 X150.590 Y129.590 E3.36941*92
Recv: ok N:39
Send: N40 G1 X149.410 Y129.590 E3.44565*92
Recv: ok N:40
Send: N41 G1 X149.410 Y120.470 E4.03493*87
Recv: ok N:41
Send: N42 G1 X149.765 Y120.595 F12000.000*86
Recv: ok N:42
Send: N43 G1 E1.33493 F1800.000*42
Recv: ok N:43
Send: N44 G92 E0*119
Recv: wait
Recv: wait
Recv: ok N:44
Send: N45 M105*22
Recv: ok T:240 /240 B:98 /100 @:79 B@:128
Send: N46 G1 X150.000 Y129.201 F12000.000*93
Recv: ok N:46
Send: N47 G1 E2.70000 F1800.000*36
Recv: ok N:47
Send: N48 G1 F900*75
Recv: ok N:48
Send: N49 G1 X150.000 Y120.799 E2.98152*90
Recv: ok N:49
Send: N50 G1 Z0.500 F12000.000*7
Recv: ok N:50
Send: N51 M0*23
Recv: ok N:51
Send: N52 G1 X149.611 Y120.611*17
Recv: ok N:52
Send: N53 G1 F900.000*95
Recv: ok N:53
Send: N54 G1 X150.389 Y120.611 E3.01898*91
Recv: ok N:54
Send: N55 G1 X150.389 Y129.389 E3.44121*93
Recv: ok N:55
Send: N56 G1 X149.611 Y129.389 E3.47866*91
Recv: ok N:56
Send: N57 G1 X149.611 Y120.671 E3.89801*82
Recv: ok N:57
Send: N58 G1 X149.225 Y120.410 F12000.000*80
Recv: ok N:58
Send: N59 G1 F900.000*85
Recv: ok N:59
Send: N60 G1 X149.225 Y120.225 E3.90690*94
Recv: ok N:60
Send: N61 G1 X150.775 Y120.225 E3.98145*80
Recv: ok N:61
Send: N62 G1 X150.775 Y129.775 E4.44078*83
Recv: ok N:62
Send: N63 G1 X149.225 Y129.775 E4.51533*84
Recv: ok N:63
Send: N64 G1 X149.225 Y120.470 E4.96287*95
Recv: ok N:64
Send: N65 G1 X149.380 Y120.309 F12000.000*95
Recv: ok N:65
Send: N66 G1 E2.26287 F1800.000*41
Recv: ok N:66
Send: N67 G92 E0*118
Recv: wait
Recv: wait
Recv: ok N:67
Send: N68 G1 X150.000 Y129.197 F12000.000*93
Recv: ok N:68
Send: N69 G1 E2.70000 F1800.000*40
Recv: ok N:69
Send: N70 G1 F900*64
Recv: ok N:70
Send: N71 G1 X150.000 Y120.803 E3.11156*89
Recv: ok N:71
Send: N72 G1 Z0.800 F12000.000*10
Recv: ok N:72
Send: N73 G1 X149.611 Y120.611*18
Recv: ok N:73
Send: N74 G1 F900.000*90
Recv: ok N:74
Send: N75 G1 X150.389 Y120.611 E3.14901*93
Recv: ok N:75
Send: N76 G1 X150.389 Y129.389 E3.57124*91
Recv: ok N:76
Send: N77 G1 X149.611 Y129.389 E3.60870*90
Recv: ok N:77
Send: N78 G1 X149.611 Y120.671 E4.02804*94
Recv: ok N:78
Send: N79 G1 X149.225 Y120.410 F12000.000*83
Recv: ok N:79
Send: N80 G1 F900.000*81
Recv: ok N:80
Send: N81 G1 X149.225 Y120.225 E4.03694*88
Recv: ok N:81
Send: N82 G1 X150.775 Y120.225 E4.11149*87
Recv: ok N:82
Send: N83 G1 X150.775 Y129.775 E4.57081*88
Recv: ok N:83
Send: N84 G1 X149.225 Y129.775 E4.64536*94
Recv: ok N:84
Send: N85 G1 X149.225 Y120.470 E5.09290*81
Recv: ok N:85
Send: N86 G1 X149.380 Y120.309 F12000.000*82
Recv: ok N:86
Send: N87 G1 E2.39290 F1800.000*46
Recv: ok N:87
Send: N88 G92 E0*119
Recv: wait
Recv: wait
Recv: ok N:88
Send: N89 M105*22
Recv: ok T:239 /240 B:98 /100 @:92 B@:128
Send: N90 G1 X150.000 Y129.197 F12000.000*90
Recv: ok N:90
Send: N91 G1 E2.70000 F1800.000*47
Recv: ok N:91
Send: N92 G1 F900*76
Recv: ok N:92
Send: N93 G1 X150.000 Y120.803 E3.11156*85
Recv: ok N:93
Send: N94 G1 Z1.100 F12000.000*10
Recv: ok N:94
Send: N95 G1 X149.611 Y120.611*26
Recv: ok N:95
Send: N96 G1 F900.000*86
Recv: ok N:96
Send: N97 G1 X150.389 Y120.611 E3.14901*81
Recv: ok N:97
Send: N98 G1 X150.389 Y129.389 E3.57124*91
Recv: ok N:98
Send: N99 G1 X149.611 Y129.389 E3.60870*90
Recv: ok N:99
Send: N100 G1 X149.611 Y120.671 E4.02804*96
Recv: ok N:100
Send: N101 G1 X149.225 Y120.410 F12000.000*109
Recv: ok N:101
Send: N102 G1 F900.000*106
Recv: ok N:102
Send: N103 G1 X149.225 Y120.225 E4.03694*99
Recv: ok N:103
Send: N104 G1 X150.775 Y120.225 E4.11149*104
Recv: ok N:104
Send: N105 G1 X150.775 Y129.775 E4.57081*103
Recv: ok N:105
Send: N106 G1 X149.225 Y129.775 E4.64536*101
Recv: ok N:106
Send: N107 G1 X149.225 Y120.470 E5.09290*106
Recv: ok N:107
Send: N108 G1 X149.380 Y120.309 F12000.000*101
Recv: ok N:108
Send: N109 G1 E2.39290 F1800.000*25
Recv: ok N:109
Send: N110 G92 E0*71
Recv: wait
Recv: wait
Recv: ok N:110
Send: N111 M105*38
Recv: ok T:238 /240 B:99 /100 @:104 B@:128
Send: N112 G1 X150.000 Y129.197 F12000.000*97
Recv: ok N:112
Send: N113 G1 E2.70000 F1800.000*20
Recv: ok N:113
Send: N114 G1 F900*115
Recv: ok N:114
Send: N115 G1 X150.000 Y120.803 E3.11156*106
Recv: ok N:115
Send: N116 M106 S38.25*115
Recv: ok N:116
Send: N117 G1 Z1.400 F12000.000*53
Recv: ok N:117
Send: N118 G1 X149.611 Y120.611*46
Recv: ok N:118
Send: N119 G1 F900.000*96
Recv: ok N:119
Send: N120 G1 X150.389 Y120.611 E3.14901*108
Recv: ok N:120
Send: N121 G1 X150.389 Y129.389 E3.57124*104
Recv: ok N:121
Send: N122 G1 X149.611 Y129.389 E3.60870*107
Recv: ok N:122
Send: N123 G1 X149.611 Y120.671 E4.02804*97
Recv: ok N:123
Send: N124 G1 X149.225 Y120.410 F12000.000*106
Recv: ok N:124
Send: N125 G1 F900.000*111
Recv: ok N:125
Send: N126 G1 X149.225 Y120.225 E4.03694*100
Recv: ok N:126
Send: N127 G1 X150.775 Y120.225 E4.11149*105
Recv: ok N:127
Send: N128 G1 X150.775 Y129.775 E4.57081*104
Recv: ok N:128
Send: N129 G1 X149.225 Y129.775 E4.64536*104
Recv: ok N:129
Send: N130 G1 X149.225 Y120.470 E5.09290*110
Recv: ok N:130
Send: N131 G1 X149.380 Y120.309 F12000.000*111
Recv: ok N:131
Send: N132 G1 E2.39290 F1800.000*17
Recv: ok N:132
Send: N133 G92 E0*70
Recv: wait
Recv: wait
Recv: ok N:133
Send: N134 M105*33
Recv: ok T:239 /240 B:99 /100 @:97 B@:128
Send: N135 G1 X150.000 Y129.197 F12000.000*100
Recv: ok N:135
Send: N136 G1 E2.70000 F1800.000*19
Recv: ok N:136
Send: N137 G1 F900*114
Recv: ok N:137
Send: N138 G1 X150.000 Y120.803 E3.11156*101
Recv: ok N:138
Send: N139 G1 Z1.700 F12000.000*58
Recv: ok N:139
Send: N140 G1 X149.611 Y120.611*35
Recv: ok N:140
Send: N141 G1 F900.000*109
Recv: ok N:141
Send: N142 G1 X150.389 Y120.611 E3.14901*104
Recv: ok N:142
Send: N143 G1 X150.389 Y129.389 E3.57124*108
Recv: ok N:143
Send: N144 G1 X149.611 Y129.389 E3.60870*107
Recv: ok N:144
Send: N145 G1 X149.611 Y120.671 E4.02804*97
Recv: ok N:145
Send: N146 G1 X149.225 Y120.410 F12000.000*110
Recv: ok N:146
Send: N147 G1 F900.000*107
Recv: ok N:147
Send: N148 G1 X149.225 Y120.225 E4.03694*108
Recv: ok N:148
Send: N149 G1 X150.775 Y120.225 E4.11149*97
Recv: ok N:149
Send: N150 G1 X150.775 Y129.775 E4.57081*103
Recv: ok N:150
Send: N151 G1 X149.225 Y129.775 E4.64536*103
Recv: ok N:151
Send: N152 G1 X149.225 Y120.470 E5.09290*106
Recv: ok N:152
Send: N153 G1 X149.380 Y120.309 F12000.000*107
Recv: ok N:153
Send: N154 G1 E2.39290 F1800.000*17
Recv: ok N:154
Send: N155 G92 E0*70
Recv: wait
Recv: wait
Recv: ok N:155
Send: N156 M105*37
Recv: ok T:239 /240 B:100 /100 @:94 B@:128
Send: N157 G1 X150.000 Y129.197 F12000.000*96
Recv: ok N:157
Send: N158 G1 E2.70000 F1800.000*27
Recv: ok N:158
Send: N159 G1 F900*122
Recv: ok N:159
Send: N160 G1 X150.000 Y120.803 E3.11156*104
Recv: ok N:160
Send: N161 G1 Z2.000 F12000.000*51
Recv: ok N:161
Send: N162 G1 X149.611 Y120.611*35
Recv: ok N:162
Send: N163 G1 F900.000*109
Recv: ok N:163
Send: N164 G1 X150.389 Y120.611 E3.14901*108
Recv: ok N:164
Send: N165 G1 X150.389 Y129.389 E3.57124*104
Recv: ok N:165
Send: N166 G1 X149.611 Y129.389 E3.60870*107
Recv: ok N:166
Send: N167 G1 X149.611 Y120.671 E4.02804*97
Recv: ok N:167
Send: N168 G1 X149.225 Y120.410 F12000.000*98
Recv: ok N:168
Send: N169 G1 F900.000*103
Recv: ok N:169
Send: N170 G1 X149.225 Y120.225 E4.03694*103
Recv: ok N:170
Send: N171 G1 X150.775 Y120.225 E4.11149*106
Recv: ok N:171
Send: N172 G1 X150.775 Y129.775 E4.57081*103
Recv: ok N:172
Send: N173 G1 X149.225 Y129.775 E4.64536*103
Recv: ok N:173
Send: N174 G1 X149.225 Y120.470 E5.09290*110
Recv: ok N:174
Send: N175 G1 X149.380 Y120.309 F12000.000*111
Recv: ok N:175
Send: N176 G1 E2.39290 F1800.000*17
Recv: ok N:176
Send: N177 G92 E0*70
Recv: wait
Recv: wait
Recv: ok N:177
Send: N178 G1 X150.000 Y129.197 F12000.000*109
Recv: ok N:178
Send: N179 G1 E2.70000 F1800.000*24
Recv: ok N:179
Send: N180 G1 F900*126
Recv: ok N:180
Send: N181 G1 X150.000 Y120.803 E3.11156*103
Recv: ok N:181
Send: N182 G1 E0.41156 F1800.000*30
Recv: ok N:182
Send: N183 G92 E0*77
Recv: ok N:183
Send: N184 M105*42
Recv: ok T:239 /240 B:100 /100 @:99 B@:128
Send: N185 M107*41
Recv: ok N:185
Send: N186 M104 S0*106
Recv: ok N:186
Send: N187 M140 S0*107
Recv: ok N:187
Send: N188 G92 E1*71
Recv: ok N:188
Send: N189 G1 E-2 F300 Z300*78
Recv: ok N:189
Send: N190 G28 X0 Y0*26
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Qidi XMax, firmware 4.2.6.5
RaspberryPi 3
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: false
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 915722240
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.5.3
