Hello everybody. Is there any way to make sure that M0/M1 command pauses print job only on printer and not also in octoprint web-interface? At the moment, when I send "M1 Change print plate" the printer stops, shows text on LCD, and waits for the button on the LCD to be pressed. This part works, but the thing is that it also pauses on web-interface which is not good for me, because I want to be able to resume print directly from the printer.
I am using plugin called OctoPrint-Print-Queue where as a change script I use M1 command. But it always pauses between print jobs in a way that I have to resume it from octopi web interface. It does not resume when I press the knob on the lcd.
Thank you
Additional information about your setup Octoprint 1.3.9, Raspberry pi zero w, prusa mk3
