I have had two failed prints now in a row where the Prusa is showing M112, Emergency Stop.
Same .gcode file and both stopped at the same spot after about 7-8hours of printing. Have been printing similar files for the last 2 weeks with no issues.
On reviewing the Octoprint.log both times before the M112 was called the printer and octoprint looped with the following. (3 sets with 5 times of each occurrence)
Recv: ok
| Send: N1021019 G1 X180.377 Y199.780 E0. 430 Y198.503 E0.02618*124
| Recv: Error:No Checksum with line number, Last Line: 1021018
| Recv: Resend: 1021019
| Recv: ok
2021-09-26 22:35:20,131 - octoprint.util.comm - WARNING - Printer keeps requesting line 1021019 again and again, communication stuck
2021-09-26 22:35:20,131 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error"
2021-09-26 22:35:20,139 - octoprint.util.comm - INFO - Force-sending M112 to the printer
This is the section of the GCode being referenced
1021003: ;WIPE_END
1021004: G1 E-0.04000 F2100.000
1021005: G1 Z3.600 F10800.000
1021006: G1 X109.458 Y23.240
1021007: G1 Z3.200
1021008: G1 E0.80000 F2100.000
1021009: M204 S800
1021010: G1 F1500.000
1021011: G1 X109.279 Y23.214 E0.00472
1021012: G1 X109.103 Y23.135 E0.00504
1021013: G1 X108.938 Y23.028 E0.00511
1021014: G1 X108.783 Y22.834 E0.00646
1021015: G1 X108.657 Y22.616 E0.00657
1021016: G1 X108.579 Y22.371 E0.00670
1021017: G1 X108.527 Y22.100 E0.00718
1021018: G1 X108.504 Y21.739 E0.00944
1021019: G1 X108.551 Y21.392 E0.00912
1021020: G1 X108.619 Y21.211 E0.00502
1021021: G1 X108.809 Y20.960 E0.00821
1021022: G1 X108.958 Y20.855 E0.00475
1021023: G1 X109.184 Y20.776 E0.00624
1021024: G1 X109.208 Y21.083 E0.00803
1021025: G1 X109.037 Y21.139 E0.00470
1021026: G1 X108.901 Y21.253 E0.00461
1021027: G1 X108.821 Y21.365 E0.00358
1021028: G1 X108.738 Y21.625 E0.00712
I cant see anything myself in the Gcode that stands out, and both failures happened on the same layer.
I am printing now in Safe Mode to see if it prints, if it fails I will reslice the models and print again.
The print is for a bed full of tokens about 35mm diameter and 5mm high. I have printed 100's in the last few week with no issues until this set.
Thought I would ask the community for other options to look at while I wait the 7 hours to see if it fails again or not.
Restarted Printer, Restarted Octoprint - Full power down of both.
Started Reviewing logs and Gcode. enabled Serial logging
Trying same Gcode in Safe Mode now - if fails again will try reslicing parts and printing again.
octoprint (1).log (246.1 KB)
Running print in safe mode now
Waiting for results
octoprint-systeminfo-20210927075745.zip (47.6 KB)
OctoPrint version: 1.6.1, OctoPi version: 0.18.0, printer: Prusa i3 mk3s+ mmu2s, firmware: 3.10.0-4481, browser: chrome, operating system: windows10pro, Raspberry pi 4
... as much data as possible
