Lately I'm having problem printing with my Prusa MK2.5, never had any problem, now evrytime I print it crashed about 10% in the printing with a M112 error.
Check on forum didn't find anything conclusive.
No... what is safe mode?
Didn't try.
I'm running Octoprint 1.9.3
Prusa Firmware is at the latest, 3.13.2
Using Prusa Slicer 2.7.1
I'm printing right now from the SD card... so I'll check it later but the things that bug me, yeah I got that error , THERMAL RUNAWAY, but it consecutively failed at the same place in my print 3 times, so I thought it was my Gcode, I've tried printing something else today and I had the same problem, here is a preview of my print (2 of them) you can clearly see it failed at the same place, so that's why I'm pulling out an hardware problem....
You can't rule out a hardware problem, because the origin of the error is the hardware at the end of the day.
Your thermistor is reading 15c lower than the target temperature, and despite whatever the printer is doing this temperature won't go up - so something must be wrong and it is shut down. Now you have to find the reason for this.
It could be that, in this specific point of the print, the cooling fan kicks in and ends up cooling down the nozzle too much. Or, when the printer has done a specific movement in this print, there is something loose in the cable that's triggered an issue here.
It's definitely nothing to do with OctoPrint, it's a printer-side issue, whether that's the gcode, firmware or hardware.
Well I guess you are right Charlie, I did have the same problem printing out of the SD Card... I've check the thermistor... seems okay but I've ordered another one, will try to fix this over the weekend.
Perhaps you could use the OctoPrint UI to troubleshoot this. No filament or gcode required. Heat the nozzle to the temperature you have been printing with. Use the Control tab and move the nozzle around on the bed (to the edges). You can do this with the nozzle close to the bed and with various cooling fan speeds. Keep an eye on the Temperature graph which should show a completely horizontal line at the selected temperature.
The thermistor itself may not be bad but the thermistor wiring may be.
OK so I've changed my thermistor.... got the same problem but found out why, at some point in ALL my prints the fan goes to 250 (weird value thought 100 was the max) so I guess now the problem is coming from my slicer, I'm using Prusa Slicer ver 2.7.1... I've check and can't find where this setting could go wild since I've never mess with that.
