M3U8 video support
M3U8 Video support
Searched in the forum already, didn't found what i'm looking for.
Last octoprint, installed it today, fresh install.
Win 10, Google chrome last release.
I have an IP Camera connected on my Wifi.
I have a direct link for the stream but it's a .m3u8
Octoprint do not support .m3u8 (or i missed something)
Question
Is there a way to replace basic webcam feature of Octoprint for IP Cam using HLS technology ?
Example link for my ip cam : http://192.168.0.31/img/stream.m3u8/
Thank you :slight_smile:
EDIT :
In the m3u8 file that my phone download when i try to access the camera, there is more to add after .m3u8 :
192.168.0.31/img/stream.m3u8?channel=1
And if i download and edit the file that is downloaded, i got things like this :
#EXTINF:1
hls/s1_clip8476.ts
#EXTINF:1
hls/s1_clip8477.ts
#EXTINF:1
hls/s1_clip8478.ts
But i don't know what to do with that
Check this post...Experimental HLS support I created a plugin based on these changes that in theory should enable HLS video support...
Hey thank you for your answer, i'd like to try it.
I installed it with plugin manager, is there a configuration file to edit or something ?
Ps : my camera needs an username and password, is it supported with your plugin ?
So again, I just ported the other person's changes into a plugin format. From my understanding you just need to enter the full address in the webcam stream URL in the standard OctoPrint settings, but if I remember correctly it will just check against the extension m3u8 and may not work with the additional information. In most html based access you can embed the username/password into the URL somehow, potentially like http://username:password@192.168.0.31/img/stream.m3u8
looks like it does not need username / pwd (tried on chrome with Play HLS app). But via OctoPrint it does not work "Webcam stream not loaded"
EDIT :
Without the "?channel=1" it shows a player but with infinite loading
It's probably a little tweak to do in the code somewhere but i don't really undetstand js so i can't figure it out
If you can get it to load inside chrome directly you might be able to utilize the WebcamIframe plugin.
Not directly, i need a chrome extension, and it's not usable as it i guess : chrome-extension://hahkjjkedonglpienpfiganogikkkoii/player.html#http://192.168.0.31/img/stream.m3u8?channel=1
