When a print finishes, or when I pause, I get 'Unknown Mcode' error. Appears as a UI message box, and in terminal. Doesn't matter for a print finish, but matters for a pause (means I can't run custom pause/resume scripts).
Rebooted Pi. Upgraded to latest Octoprint/octopi.
M3D Micro printer connected to Pi 3B+
(from UI) OctoPrint 1.3.10 running on OctoPi 0.16.0
(M115) Recv: ok REPETIER_PROTOCOL:2 FIRMWARE_NAME:Micro3D FIRMWARE_VERSION:2016040401 MACHINE_TYPE:The_Micro X-SERIAL_NUMBER:BK16122101050044
**From terminal, pressing pause during job:
Send: N70 G0 X103.300000 Y9.500000 Z-0.146061 E32.73402 F1000**106
Recv: ok 70
Recv: ok 71 #pressed [pause] in UI
Changing monitoring state from "Printing" to "Pausing"
Send: N72 M40018
Recv: ok Unknown M���code
Send: N73 M11419
Recv: ok 73
Did not receive parseable position data from printer within 10.0s, continuing without it
Changing monitoring state from "Pausing" to "Paused"
[...] #pressed [cancel] in UI
Changing monitoring state from "Paused" to "Cancelling"
Related, is there any octoprint plugin/setting that will allow the server to ignore specific gcode commands? I looked through the menus and advanced menus and saw nothing.
** Problem is I think I'll need position tracking to allow a 'resume' script
G0 ((pause.position(X)))
I might also suggest it to Donovan (M33 fio) as there is a section in his plugin which performs on-the-fly processing (e.g remove temp commands, remove fan commands). A key-in for 'unsupported g-codes' or such might help (me and others)
You could modify my own OctoPrint-Toggle-Autolevel plugin. This one basically looks for G29 and replaces it with ;G29. Since it's a single-file plugin, the thought would be that you could modify it, place it where it needs to be and it would then just work.
Not wanting to sound newb, but I kind of am... I don't know how to install/enable a plug-in outside Plugins manager... doh
If someone could point me to an instructional post, I'll follow up tonight.
Gina, I tried disabling the 'log on pause' setting (whatever it's called), and I still received the error. Will try it again tonight to be sure.
I know that the m3d (firmware?) has pre and post g-code that runs regardless of any .GCO contents (and independent of Gcode scripts in octoprint settings).
