When trying to print an item from withen Octoprint the hot end starts warming up, and once its at temperature I receive the error
Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: M600 Hotend too cold to change filament
Increasing timeout timer, re flashing firmware, verified proper Filiment run-out sensor settings. I even tried updating to the newest firmware version of Octoprint.
I am using the newest version of Octoprint and Marlin 1.1.8. I am able to load a print from the SD Card directly on the printer and print items without any issue. I know the filliment sensor is working fine because I have tested removing the filiment and the printer will stop and have me change it.
When trying to print with Octoprint, one of two things will happen. Some times, i will get a message on the screen of the CR-10S that will say "Changing Filliment" and it will eject the filiment and have me load it back up. when doing so it gets stuck in a loop and comes back to the "Changing Filiment" screen.
Other times (Which happens most often) I get the message in Octoprint that says
Please help!
Thank You.
