I just installed a new cooling fan mount that shifted the BLTouch probe over a bit so I need set that up.
I can't just reprogram/re-flash Marlin because I had spent a lot of time customizing this one for this particular machine and... that file has long been lost (old hard drive died). Not sure if I can pull it off Octoprint or something.
I tried (in octoprint's command panel) using M851 X-59 Y-9 (proper BLTouch probe distance from nozzle) and then hitting send. It returns:
Recv: echo:Probe Z Offset: -2.80
Recv: ok
^SO it appears that it's only allowing me to change the Z offset but not the X and Y... but I do the following anyway: I send M500 to store settings, then M501 to load those settings (I've also tried just hitting M500) But... doesn't appear to actually change anything. Still homes to the same exact spot and I can't run mesh bed leveling because it errors out since the BLTouch is now over the edge of the bed.
I'm thinking that yeah for some reason it's just not letting me effect the X and Y offsets. I do remember setting this up in the configeration.h file before. Could that be why it's just not letting me change those values now? If so then I'm in bigger trouble because like I said, that file is long gone (unless I can get it off this micro sd card in the raspberry pi I'm using for OctoPrint...
Yes
Complete Logs
Link to octoprint.log: https://drive.google.com/file/d/1oUYG7J5IPHcjL3ebpm3Yrcrd87857KFY/view?usp=sharing
Marlin 1.1.9
Octoprint version: 1.5.2
Printer: CR-10S 400
What a bummer. Well I guess I'm either starting from scratch or just re-installing my not so great fan mount... will probably do that instead of starting over.
