Trying to get octoprint rolling on a Makerbot Replicator z18, but the octopi won't detect the usb connection.
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Lots of google... checked dmesg and the device does show up so raspbian defintiely sees it. Not sure what to make of the /dev/tty* output
[ 1773.107511] usb 1-1.1.2: new high-speed USB device number 9 using dwc_otg
[ 1773.238567] usb 1-1.1.2: New USB device found, idVendor=23c1, idProduct=0006, bcdDevice= 3.08
[ 1773.238583] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1773.238593] usb 1-1.1.2: Product: MakerBot Z18
[ 1773.238602] usb 1-1.1.2: Manufacturer: MakerBot Industries
[ 1773.238611] usb 1-1.1.2: SerialNumber: 23C100063C7059005132
[ 1778.317943] usblp 1-1.1.2:1.0: usblp0: USB Bidirectional printer dev 9 if 0 alt 0 proto 2 vid 0x23C1 pid 0x0006
and here's the output of /dev/tty*:
crw-rw-rw- 1 root tty 5, 0 Apr 9 10:37 tty
crw--w---- 1 root tty 4, 0 Apr 9 09:17 tty0
crw--w---- 1 root tty 4, 1 Apr 9 09:28 tty1
crw--w---- 1 root tty 4, 10 Apr 9 09:17 tty10
crw--w---- 1 root tty 4, 11 Apr 9 09:17 tty11
crw--w---- 1 root tty 4, 12 Apr 9 09:17 tty12
crw--w---- 1 root tty 4, 13 Apr 9 09:17 tty13
crw--w---- 1 root tty 4, 14 Apr 9 09:17 tty14
crw--w---- 1 root tty 4, 15 Apr 9 09:17 tty15
crw--w---- 1 root tty 4, 16 Apr 9 09:17 tty16
crw--w---- 1 root tty 4, 17 Apr 9 09:17 tty17
crw--w---- 1 root tty 4, 18 Apr 9 09:17 tty18
crw--w---- 1 root tty 4, 19 Apr 9 09:17 tty19
crw--w---- 1 root tty 4, 2 Apr 9 09:17 tty2
crw--w---- 1 root tty 4, 20 Apr 9 09:17 tty20
crw--w---- 1 root tty 4, 21 Apr 9 09:17 tty21
crw--w---- 1 root tty 4, 22 Apr 9 09:17 tty22
crw--w---- 1 root tty 4, 23 Apr 9 09:17 tty23
crw--w---- 1 root tty 4, 24 Apr 9 09:17 tty24
crw--w---- 1 root tty 4, 25 Apr 9 09:17 tty25
crw--w---- 1 root tty 4, 26 Apr 9 09:17 tty26
crw--w---- 1 root tty 4, 27 Apr 9 09:17 tty27
crw--w---- 1 root tty 4, 28 Apr 9 09:17 tty28
crw--w---- 1 root tty 4, 29 Apr 9 09:17 tty29
crw--w---- 1 root tty 4, 3 Apr 9 09:17 tty3
crw--w---- 1 root tty 4, 30 Apr 9 09:17 tty30
crw--w---- 1 root tty 4, 31 Apr 9 09:17 tty31
crw--w---- 1 root tty 4, 32 Apr 9 09:17 tty32
crw--w---- 1 root tty 4, 33 Apr 9 09:17 tty33
crw--w---- 1 root tty 4, 34 Apr 9 09:17 tty34
crw--w---- 1 root tty 4, 35 Apr 9 09:17 tty35
crw--w---- 1 root tty 4, 36 Apr 9 09:17 tty36
crw--w---- 1 root tty 4, 37 Apr 9 09:17 tty37
crw--w---- 1 root tty 4, 38 Apr 9 09:17 tty38
crw--w---- 1 root tty 4, 39 Apr 9 09:17 tty39
crw--w---- 1 root tty 4, 4 Apr 9 09:17 tty4
crw--w---- 1 root tty 4, 40 Apr 9 09:17 tty40
crw--w---- 1 root tty 4, 41 Apr 9 09:17 tty41
crw--w---- 1 root tty 4, 42 Apr 9 09:17 tty42
crw--w---- 1 root tty 4, 43 Apr 9 09:17 tty43
crw--w---- 1 root tty 4, 44 Apr 9 09:17 tty44
crw--w---- 1 root tty 4, 45 Apr 9 09:17 tty45
crw--w---- 1 root tty 4, 46 Apr 9 09:17 tty46
crw--w---- 1 root tty 4, 47 Apr 9 09:17 tty47
crw--w---- 1 root tty 4, 48 Apr 9 09:17 tty48
crw--w---- 1 root tty 4, 49 Apr 9 09:17 tty49
crw--w---- 1 root tty 4, 5 Apr 9 09:17 tty5
crw--w---- 1 root tty 4, 50 Apr 9 09:17 tty50
crw--w---- 1 root tty 4, 51 Apr 9 09:17 tty51
crw--w---- 1 root tty 4, 52 Apr 9 09:17 tty52
crw--w---- 1 root tty 4, 53 Apr 9 09:17 tty53
crw--w---- 1 root tty 4, 54 Apr 9 09:17 tty54
crw--w---- 1 root tty 4, 55 Apr 9 09:17 tty55
crw--w---- 1 root tty 4, 56 Apr 9 09:17 tty56
crw--w---- 1 root tty 4, 57 Apr 9 09:17 tty57
crw--w---- 1 root tty 4, 58 Apr 9 09:17 tty58
crw--w---- 1 root tty 4, 59 Apr 9 09:17 tty59
crw--w---- 1 root tty 4, 6 Apr 9 09:17 tty6
crw--w---- 1 root tty 4, 60 Apr 9 09:17 tty60
crw--w---- 1 root tty 4, 61 Apr 9 09:17 tty61
crw--w---- 1 root tty 4, 62 Apr 9 09:17 tty62
crw--w---- 1 root tty 4, 63 Apr 9 09:17 tty63
crw--w---- 1 root tty 4, 7 Apr 9 09:17 tty7
crw--w---- 1 root tty 4, 8 Apr 9 09:17 tty8
crw--w---- 1 root tty 4, 9 Apr 9 09:17 tty9
crw-rw---- 1 root dialout 204, 64 Apr 9 09:28 ttyAMA0
crw------- 1 root root 5, 3 Apr 9 09:17 ttyprintk
see above
Octoprint 1.4.0
Raspbery pi 3 B+
