When I start a print from SD card everything works fine, untill I hit the cancel print button in octoprint. Instead of canceling the print, it changes it's status to "Print Pauses" on the LCD display and moves to parking position. The nozzle cooles down and I can restart the print via octoprint by klicking on reheat and continue in some message windows. Then the Printer wants to continue, by moving to the right place, but stops for a short time, homes again and turns off the nozzle and bed (I think because of the "after cancel print GCODE script" in octoprint). After that the print starts again without heated nozzel and bed.
When i print a file stored on the rasPi everything works fine. But i have some artifacts on the print caused by a slow data transfer. This issue can be solved with a workaround but thats another topic. I want to print directly from the SD card.
The problem occured after i updated my Ender 3 Max on Marlin 2.0.9.2
I used the Configuration.h and Configuration_adv.h provided by Marlin for the Ender 3 Max to
compile the Firmware.
I had to disable Z_SAFE_HOMING, otherwise the printer didn't home correctly
I disabled S_CURE_ACCELERATION in config and LIN_ADVANCE in the config_adv
I enabled CLASSIC_JERK in cofig (to disable junction deviation)
MAY BE IMPORTANT: I enabled the EMERGENCY_PARSER
I tried to analized the problem and may traced down the reason in the serial_log
serial (29).log (64.4 KB)
after i canceld the print (Timestemp: 2021-12-17 12:48:17,451)
there is the command M25 witch means according to marlinfw.org: "pause sd print"
the right command should be M524 (Abort SD print), or is there another problem I missed?
My idear is to change the M25 to M524 when i kick on the print cancel button, but i don't know how to do that. But maybe there is an other option I don't get.
I hope you can help me solving this problem.
Not tried
octoprint-systeminfo-20211217125832.zip (49.8 KB)
Octoprint v1.7.2, OctoPi v0.18, Firmware Marlin 2.0.9.2, Browser Chrome, Win10
